ScaryKat By Paul Thomason
Home Forums Scratch build ScaryKat By Paul Thomason
Viewing 22 posts - 51 through 72 (of 72 total)
  • #51753
    mike farrell
      @mikefarrell21522
      Now then Dave That's not a Bakewell Tart is it . Paul will pull it off as with many others in the past ,I still do not know how but will wait and seeindecisionMichael
        Michael:
        Thank you for your vote of confidence.
        Dave:
        pie-in-sky.jpg So the gauntlet has been thrown and the challenge made, honour demands my response.
        As its my choice of challenge I choose the design of a 1m long high speed model boat capable of reaching 40mph. So Mr M will you accept the challenge or will your pie in the sky end up being humble pie?
        The principal of the tilting hulls is based upon the way a skier turns during a slalom.
        Edited By Paul T on 31/08/2014 18:39:44
        #51755
          If that thing has a turning circle smaller than Titanic's then I'll happily make the custard, Doc.
          (You cheated and added a bit while I was posting!)
          and no – duells have been illegal for centuries and I've two models on the go already – with no elves to help me.
          Edited By Dave Milbourn on 31/08/2014 18:40:21
          Edited By Dave Milbourn on 31/08/2014 18:42:33
          Edited By Dave Milbourn on 31/08/2014 18:43:40
          #51756
            Hello Paul…..A few questions
            Why have you opted for this strange parallelogram arrangement?
            What prevents the shape flopping about on the straight?
            Why the obsession with turning corners?
            Why are the rudders not behind the props?
            I'm sure we all would like to know the answers to the above questions?
              If you don`t mind me saying so, Paul and Dave, I don`t like the present name for this controversial model, it`s not quite right
              How about…….."Thom Kat" instead?……..Not bad?
              I think it needs Pauls name on it, because the design is pure Paul Thomason
              If Paul likes ScaryKat, then that`s the name
              lnvisibleman
                @lnvisibleman
                Mr P T
                I have a hankering to use a pair of these
                What do you think ?
                Mike
                Edited By lnvisibleman on 31/08/2014 23:42:56
                #51772
                  Hi Bob
                  Why have you opted for this strange parallelogram arrangement? Its the easiest geometry to maintain the positions of the superstructure and hydrofoil whilst the sponsons are banking.
                  What prevents the shape flopping about on the straight? The sponsons will be held in the correct position with either heavy duty servos or, and more likely, high torque geared motors. If you visualise the parallelogram these motors would be fitted on each of the top corners.
                  Why the obsession with turning corners? Obsession? If the boat can turn tighter corners then it will be quicker around a course.
                  Why are the rudders not behind the props? Given that the sponsons tilt the best position for the rudders is behind the superstructure as this will have far less of a tilt letting the rudders be far more effective.
                  Re the name
                  There is a commercial range called Tom Cat and whilst I appreciate there is a difference I'm not over bothered about having my name on every design so we will stick with ScaryKat
                  Mike
                  To make this thing live upto your expectations we will need a minimum of 25000rev which I suspect is only achievable with surface piercing propellers and some high tec transmission.
                  Edited By Paul T on 01/09/2014 15:28:53
                  #51773
                  lnvisibleman
                    @lnvisibleman
                    this seems to be where the brushless mystery deepens. 25,000 rpm is very easy to achieve ( I have found some that will get up to 40,000 on 3s lipos  http://www.hobbyking.co.uk/hobbyking/store/__21483__NTM_Prop_Drive_28_36_3000KV_755W.html&nbsp  but those motors that will deliver the revs all seem to be of quite a low relative power ( watts ) compared with the slower reviving high wattage units.
                    Which is more important when trying to achieve high speeds ? Power or revs?
                    Mike
                    Edited By lnvisibleman on 01/09/2014 15:27:26
                    Edited By lnvisibleman on 01/09/2014 15:30:13
                    #51774
                      Mike
                      Try looking at your problem from a different perspective…………….the power to weight ratio.
                      Diede van Abs
                        @diedevanabs87670
                        Hi Paul,
                        that looks like a very interesting concept, I am very curious as to how this will work out… I think you do need some very heavy duty stuff to keep the hulls in check, though. At high speed there is a lot of forces working on the hulls.
                        Second; you will need to move the props more to the rear, to prevent them from hitting air when the speed picks up – aim to extend the propshafts 10% of the hulls length.
                        As for the revs: 25000rpm should be a good target, you could go a liiiitle over. the 40k Mike is referring to, however… don't do that. You'll just stir up the water without much forward thrust.
                        #51777
                        lnvisibleman
                          @lnvisibleman
                          That's a shame !! I like stirring,
                          Mike
                          #51778
                            Hi Diede
                            The forces on different sections of the boat are immense and are constantly changing as the hulls move independently of each other but the biggest design problem isn't resisting the force on the hulls, the main problem is finding a non exotic material to construct the cross hull connections such as the hydroplane wing from.
                            I cant use carbon fibre or titanium so at the moment I am looking at epoxy laminations reinforced with stainless steel wire.
                            lnvisibleman
                              @lnvisibleman
                              For why can we not use carbon fibre? or GRP ?
                              Or multiple layers of 1.2mm plywood even ?
                              Edited By lnvisibleman on 01/09/2014 16:19:24
                              #51780
                              lnvisibleman
                                @lnvisibleman
                                Could it be that the " rudders " are above water ? More like an aeroplane rudder ?
                                Mike
                                #51781
                                  Mike
                                  For why can we not use carbon fibre?… to expensive or GRP ?… to fragile.
                                  Or multiple layers of 1.2mm plywood even …to fragile
                                  Could it be that the " rudders " are above water ? More like an aeroplane rudder .. Yes
                                  #51782
                                  lnvisibleman
                                    @lnvisibleman
                                      Mike
                                      I appreciate your enthusiasm but some things are beyond the average model boat builder, Carbon Fibre is an exotic material and the pieces are critical parts and have to be correctly manufactured, The cost of production in an autoclave would outweigh the advantage of using the material as opposed to wire reinforced epoxy which falls comfortably into the DIY category.
                                      lnvisibleman
                                        @lnvisibleman
                                        OK, I'm off back to my thumb twiddling corner
                                        #51793
                                          What about Vacform?? shouldnt be too difficult should it?? just got to make wooden patterns and take it to a vacform/plastics setup. Its something I might try later on, and also as a plus the styrene glues very well.
                                          An alternative is to make two hull parts from styrofoam and have the shell moulded over this, but leave the styrofoam in place and carve out the space you need. Can use thinner styrene then.
                                          Hull could also be made of slightly thicker stuff than the normal kit for durability…?
                                          lnvisibleman
                                            @lnvisibleman
                                            I have started on the frames, all credits to PT for inspiration.
                                            Power will be supplied by twin water jet units powered by brushless motors, Total power supplied will be approx.2,600 watts and weight will be around 3.2 Kg.
                                            build will be from 1.5mm ply with grp reinforcing and ( just for the hell of it ) the bow foil will be Carbon fibre composite.
                                            #52413
                                              If only you had asked me first I could have saved you so much time and money.
                                              Firstly I would have told you that jet units wont work in a tilting hull because, as the hulls tilt, the intakes rotate out of the water.
                                              Secondly, and far more fundamentally, the original tilting hull design that you plagiarised simply doesn't work as when the hulls tilt greater than 10deg in a tight corner they flip over.
                                              The problem that designers have with inspiration is that the original flash of thought might look good on paper but it can take many months and many changes to bring that brilliant thought to life. ScaryKat is now in its 7th reincarnation and has changed quite a lot since our early discussions. for example the centre of mass has moved down to below the waterline (this stops the hull flipping over) and the bow has increased in depth to 120mm. But then I suppose that you, being a self confessed Phd will have already figured this out for yourself.
                                              You were offered the hand of friendship and you have repaid it with unkind words, this aspect of the whole affair is the part that has saddened me most of all.
                                              #52423
                                                Invisibleman has left the Forum.
                                                No further comments please.
