Can anyone please suggest somewhere I can read up on sail servos, how to set them up etc.
Now I’ve finished my Clyde Puffer I am renovating a rather nice old motor/sailer. It had an old 27mh receiver in it but other than that I don’t know how old it is. The existing sail servo, working 3 sheets is still working but I don’t understand how it is supposed to work.
It has a drum on top with a very thin wire running twice round it in a continuous loop round a pulley under the foredeck with a triangular plate in the wire with the 3 sheets attached which then run up through 3 holes in the deck to the sails.
When I operate the right hand stick the servo works and runs the triangular plate forward or back in the hull but if I stop the stick part way forward or back the servo then runs back to the centre position. The right hand stick is on spring return to centre at the moment. I think I want the sheets to stay where I put them, not keep returning to the centre when I stop moving the stick.
Are you confused, because I am. Is the old sail servo incompatible with the modern transmitter, is it perhaps faulty, what could I or should I replace it with?
I have a vague recollection of, when it was received new, taking the back off of one of my transmitters to fit a spring to make the right stick return to centre when released but I cant remember if it was the transmitter I am using with this boat.
I’d be grateful for any suggestions or help.
Thanks
Stephen
PS I do have another option, furl the sails and just use her as a motor but that would be a shame.
