Wayne. As paul is indicating, there is no clear cut answer to this.
An "X" pitch prop is of a much courser pitch than an "S" . The props are usually marked on them so Westbouirne should be able to find out. As previously stated, these props are very cheap and a small selection of both pitches in 35mm and 40mm, plus a couple of 40 and 45mm three blade ones will not cost much and enable fine tuning to acheive good performance/max efficiency of the motor. It is not money wasted, as these are very common sizes and they will be used in something later on, if only for comparisons.
i would advise getting an ammeter to measure the current draw of the motor on various props. This is really the only way to go, and will stop dangerous overheating and so on. Again, doesnt have to be an expensive one.
