Hi Bob,
Yes she was well too high in the water. Problem was that I could only bleed her tanks and not blow them. The fish tank valve proved totally inadequate. Had to the farmer's solution!-
It worked but gave no real control over her waterline depth. Had to settle for a high water line for safety. Still I was very pleased for a launch. She has bags of thrust if needed and the rudders worked better than expected. Running astern she was dipping with the hydroplanes at neutral so need to work out what all that's about but full ahead the hydroplanes had little effect.
The next move is to sort the diving gear so that I have accurate control over her buoyancy and water line. This means some simple soldering to plumb the tanks back into the hull and then plumbing the Vauxhall solenoid valve to vent the ballast tanks. Then I have to sort the blow system. Here;s the start-
It's a needle valve with a massive outlet designed to be pushed onto a bike tyre and inflate it in seconds. The cylinder pressure is 900 psi. Job one, take it apart-
Chuck most of the gubbins away and make a restricted outlet. This is a very small hole at 0.25 mm (10 thou) so you need an accurate set up. Notice the chuck held in a chuck!-
Here it is fitted to the valve-
And here it is with the feed tube attached-
The small hole completely desensitizes the control valve. allows a progressive blow and keeps all the high pressure stuff within the confines of the valve itself. I works a treat! Have spent much of the holidays sinking and surfacing Kitty Kan tins in the bath. Now just need to get the stuff installed.
There is no way Bob she is going in with a safety line. Have ordered mi wet suit off ebay!
Len
