Hello Len
I hope you don't mind me posting this?…….The only connection with your thread is that it is a submarine story and my model looked like the Resurgam!
I once made a tin plate submarine, from three tin cans soldered together, end on, with an Andrews Liver salts tin for the conning tower
I got the design from a Boy's Own mag in 1953…..I was only 16 then
Underneath was a non return valve which let water out via a rear pointing tube…..but not in
At the top of the hull, was a float valve, which let water in, but not out
In the conning tower was a wire basket, in which was placed a block of Calcium Carbide
The sub was placed in the bath which settled down, letting water in, via the top valve, until the water reached the Carbide!
Carbide and water don't like each other and a high pressure gas is produced!
The pressure closed the inlet valve and forced the water out of the sub, through the bottom pipe which propelled the sub forward
When the inside water level had dropped below the carbide block, the reaction stopped and water entered the sub once more, through the top valve
The cycle was repeated…..Clever?…eh?
Did it work?……Don't know…..Carbide was not on sale anymore!…..Doh!
Thank you, Len
