I have printed the frames, keel and building board plans and have not had any issue with "shadows" as Bob has reported. Do agree 10.pdf and 15.pdf appear to have a problem as indicated. I have noted the lines indicating the cut out for the propshaft tube on the keel are not parallel, not a problem but thought I should notify the drawing office.
However here is my quick review.
The purchasing process is simple via the JustGiving site and I had no problems with the download e-mail sent direct by Paul. I do have fibre broadband so speed was not a problem.
The instruction pack is, as Bob has said, absolutely spot on. The template drawings are very clear, I particularly like the inclusion of the "Building Board & Frame Positions" templates, a really good idea. Another useful addition is the "Scale Checker" I made use of this as the first frame I printed was under scale and on checking my printer settings I found the page size setting had reverted to Letter instead of A4. I also found it necessary to set for no margins. I would imagine this may depend on make and type of printer.
In conclusion, with the excellent instructions and frame pack a first time scratch builder should not have any problems. If they do there is plenty of help available via this thread and I would suggest it is well worth having a look through before starting.
I really believe the value of these drawings and instructions are well worth the donation I chose to pay. Again as Bob has said a lot of hard work has gone into this project and the least we can do is to reward Paul by donating to the charity he has decided to support with the proceeds. Even if you don't want to build the model it is my belief the instructions and templates will provide you with a great insight into building a hull from scratch and help you design something of your own. I join with Bob to urge you to donate what ever amount you can afford (£5 minimum).
Don't forget if you are a UK tax payer you can help the charity further by the "Gift Aid" scheme.
Cheers
Edited By Dave_P on 10/11/2013 14:10:51
Edited By Dave_P on 10/11/2013 14:13:49
Edited By Dave_P on 10/11/2013 14:14:47
