Hi Robs I believe there is a distance between props and rudders where it is too big and the two do not work together. In the first instance, it is wise to know how each of the devices work, and then, it is easier to see how they work together. the rudder is a device that deflects a flow of water to one side. It cannot perform this function if there is no flow of water past itor, the boat is under way. The technical expression is that the boat has steerage way.If the vessel is standing still, and the motors are turning, there will be a column of water pushed astern by the propellor past the rudder the rudder will deflect the water to one side , and as we are told by physics teachers, every action has an equal and opposite reaction, so the action of pushing the water to one side will produce a reaction of equal force pushing the stern of your boat to the other side. at this point, I call your attention to the photo in the album Mikes Boats titled Tamar gear which is a photo of the hand made props and rudders for my model lifeboat a bit difficult to work out, as they are sitting snugly in a tunnel hull. From this , you can see the distance between rudders and props , and see how the props would push water past the rudders. The first thing to do is get the baby wet, chuck it in a pond and see what happens, does it go fast or slow ? does it steer left and right >? in any case, the answer to any wrong answers lies in judicious modifications,props can be moved for’d or aft with the addition or subtraction of thrust washers, and a rudder could be extended by soldering on a bit of sheet metal to extend it in any direction. You will see from my photo, that there is a bit of rudder ahead of the shaft centre linewhich I believe makes the servomotor’s job a little easier addin g a bit of rudder that helps the turning motion of the shaft. historically, rudders have had balancing tabs on them to reduce the amount of effort needed to turn them to see this at first hand, float your model in a bath and feel the push of the motors when they are running see the stern swing when you operate the steering servo, check out the speed control before your model goes out of range in the park pond. remember a quality product is right first time, and flight safety is no accident….Mike Davidson……….
Edited By Mike Davidson on 23/04/2009 16:40:43
