From recent posts on this Forum and others it seems apparent that a lot of people are having problems and queries associated with their electronic kit.
Way back in the days of 27Mhz and 40mhz you could buy your transmitter, receiver, servos and speed controller and if they were all from reputable manufacturers and you connected them up according to the instructions everything would pretty much work out of the box. I am still using a couple of Futaba M series sets which continue to work perfectly. Mixers were mechanical or you just rigged up a couple of microswitches to cut out the inboard prop when the rudder was hard over – no electronics, you could actually see it happening!
Now of course we have super duper 2.4 gigahertz sets and intelligent speed controllers which are supposed to be the bee’s knees – but it doesn’t always seem to work out that way does it?
2.4Ghz has many advantages in that crystals are no longer required but the frequency is also in use for all sorts of other devices which can potentailly stick a spanner in the works. At home my wireless computer router signal can be corrupted if I turn on the gadget which sends TV signals from the downstairs set top box to the upstairs TV. And if the microwave in the kitchen is turned on then it scrambles the TV signals. And of course 2.4Ghx is no good for controlling submarines as the signals cannot penetrate the water.
Then we seem to have problems with binding Rxs. One to one OK – usually; but if you want to use one TX with several RXs in different boats people say it aint quite so straightforward!
And then there are the speed controllers, some of which appear to be rather temperamental when hooked up to certain receivers (I’m sure Dave M will explain why this can happen and why his products are not affected!)
Computerised TXs are also a big step forward with model memory settings but most of them were originally designed for aircraft and helicopter applications so trying to apply the mixer features in a marine situation can be problematical to say the least!
I’m not trying to knock progress of which there has been a great deal in recent years but newcomers to the hobby, which we really do need(!), seem to find it all very confusing and offputting.
So what do others think?
