Precedent Perkasa – hulls
Home Forums Building Kits Precedent Perkasa – hulls
  • #80691
    Andrew Norley
      @andrewnorley93998
      Hi
      recently rescued the above 1:35 kit. It the plywood hull but I’m missing the keel and a couple of bulkheads. As a backup to failing to recreate a balanced n streamlined hull, I’m thinking of using the Kingston mouldings Perkasa/brave borderer GRP hull. I’m planning on using 3 props with electric motors
      Has anyone used this hull/kit combo ? And if so any hints/instructions would be most welcome
      Thanks in advance
      Andrew
      Andrew Norley
        @andrewnorley93998
        #80696
          HI Andrew
          I have sent you a Message.
          I have the Precedent booklet (PDF copy)with the keel and frames.
