Posted by Dave Milbourn on 14/11/2016 16:03:57:
That's an inrunner, John. These are generally too fast for anything except a genuine fast-electric hull and a surface drive. If you think about it, 18.5v x 2200kv = a lot more RPM than an ED Otter – by a factor of at least five! As I said, I've no experience of large brushless motors but I think an outrunner with a kv of less than 1000 would be a much better bet for this model with its fully-submerged prop.
Well, lets stick my neck out and try to provide some actual data, even though I have no experience in the field! I also have not used a large brushless motor, but we should be able to get some ball-park figures by considering power requirements.
The big Aerokits used to be suitable for motors of around 10cc. I think the 3.5cc motor installed would have made it plane, but would not have had an 'exciting' performance. I used to use a Merco 35 in a Sea Commander, and I could have done with a bit more poke…
Now the 10ccs used to be able to put out a bit more than 1Hp – perhaps about 1Kw? And if we guess that you will be using 12-15V, that equates to about 100Amp (in round figures). That would probably be able to run quite fast, so running it less fast would minimise the cooling requirements.
Now I think that above 50A or so you tend to hit a 'price point'. Below this there are a lot of motors at quite cheap prices – above this there are fewer motors, and many become very expensive. 50A-60A is meant to be the equivalent of the old 10cc (0.60cuin) motors – See, for instance, the Turnigy G60 range **LINK** and these are 60A. Of course, these are expected to run in a cooling draught in front of an aeroplane.
So I would start off by looking for a brushless motor perhaps 50mm in diameter – between 50-100 Amps. Down at the lower end of the Amp range I would be using higher voltage batteries and adding cooling – by about 70Amps I would not be worrying about this so much.
I'm happy to be corrected if anyone knows better – but those figures seem to make sense to me…
How does that sound, DM?
