Evo Stik, not the rubbish they now put in tubes, but the original stuff in tins which they sell for carpet and lining vehicles with trim.
Thin coat on the substrate, thin coat on the deck plank veneers, one by one and put them on after 5-10 minutes.
I used to use it on all my customer builds, including the Rivas, where the 7 hull planks shouldn't even show. I then epoxied the veneer, stained the epoxy (always stain the finish, never the wood) and then UV varnished over that. Glass like finish and no lifting of the veneer. I would never use PVA for anything! Admittedly the decks were solid wood, plank, caulking, plank, fixed with epoxy. Real Riva decks, however, contrary to popular belief, were plywood, made in High Wycombe and transported to Italy!
I am currently re-veneering my son's Triumph Renown dashboard this way and he is delighted with it.
Martin
