Hello Alan
There are many ways of installing motors………Have a look at my suggestions……..
Screw the motors, side by side onto a small baseboard.
Fit a 3mm packer below each motor mount……..(for emergency adjustment later)
Assemble the couplings and prop shafts to the motors
If you have plenty of space available inside the hull, extend the motor base to allow the prop shafts to be aligned properly whilst still on the bench, by fitting suitable packing pieces under the prop tubes
Cut the holes in the hull stern and fit the complete assembly into the hull, with the prop tubes protruding
The complete assembly can now be adjusted, up and down, until it looks right
Cut a cross support to go across the hull and when you`ve decided that the angle is ok….glue the support to hull sides, using epoxy
That`s just about it really
All the best…..Bob
