Model RNLI Lifeboat – Tyne Class
Home Forums Buy/Sell or Trade Model RNLI Lifeboat – Tyne Class
  • #40184
    NormanT
      @normant
      Model Lifeboat RNLI RNLB Tyne Class – Ruby and Arthur Reed – Cromer
      Scratch Built from orginal RNLI Imperial Plans.to 1/12 scale.
      Large Model 47" long, 11"(33cm) wide by 30"(75cm) high including ariels.
      Housing space in back and cockpit compartments for engines and gears.
      Took 9 months to build and Hull tested for water resistance.
      Due to size of model this will be a pick-up only from Norwich.
      Will accept offers over £500
      Email me for any further details.
      [email protected]
       Length of model corrected to 47 inches – Colin
      Tyne class RNLI Lifeboat
      Edited By Colin Bishop, Website Editor on 10/04/2013 18:51:06
      NormanT
        @normant
        RNLI Lifeboat – Tyne Class – Ruby and Arthur Reed – Cromer
        #40185
          Hi Norman if it's 37 inches long, it will have been built to 1:16th scale as the Tynes were 47' long and if built to 1:12, the model would also have been 47 inches long………..nice model just the same….and would go well with Slipways 1:16th Trent and Tamar boats.
          neil.
          Edited By neil howard-pritchard on 09/04/2013 22:30:28
          Edited By neil howard-pritchard on 09/04/2013 22:31:28
          #40187
          Kimosubby Shipyards
            @kimosubbyshipyards
            Got to agree with Neil (and I'm RNLI myself), Tyne class are 47 footers, thats why their numbers are "47-006" etc the 47 is the boat length, in this case in feet.
            Your previous posting was for a Mersey class, Norman, and their numbers are "12-012" etc the 12 being 12 metres, whereas the Oakley class numbered "37-016" their length being 37 feet. Could you have got your dimensions mixed before, as you were quoting 47' for a Mersey at 1/12 and now are quoting 37' for a Tyne at 1/12?
            The new Shannons will be numbered "13-001" as they are 13 meters long. It's all in the numbers. So a 1/12 Shannon would be 42.6" or 1.083 metres.
            Still, its a ery nice looking Tyne from your pictures, and although I was brought up on Oakleys and Merseys, in the Irish Sea we always think of the Tyne as the best sea boat – especially in a following lumper!
            Kimosubby.
            #40190
              Hi Kimo…
              the Shannon is in Fleetwood at the moment, having some slip plates fitted to her bum….she came in last night and will be craned out today…..friday she'll be heading over to your neck o' the woods…Isle of Man
              Neil.
              #40191
              Kimosubby Shipyards
                @kimosubbyshipyards
                Hello Neil,
                she's arriving here for my birthday, I'm qualifying for my bus pass on the 12th – so what's so glorious about that.
                Hope to take a good look around, and who knows, might get a quick trip out too!
                Cheers, Kim
                #40199
                NormanT
                  @normant
                  Just got in and read the comments (emails) and yes you are all correct the model is 47" and not 37". I should have been more careful before publishing. Good to see people looking at my posting.
                  If there is a way to amend the original message, it is eluding me at the moment.
                  Norman
                  I have altered it for you – Colin
                  Edited By Colin Bishop, Website Editor on 10/04/2013 18:51:44
                  #40203
                    Posted by Kimosubby Shipyards on 10/04/2013 09:29:23:
                    Hello Neil,
                    Cheers, Kim
                    I got to have a sail on her this morning Kim………glorious……..only a short one from the pen at Fleetwood RNLI to the Wyre dock, for lifting out………..but boy what a treat………..my daughter enjoyed it too.
                    neil.
                    #40204
                      Kim
                      Check out that bus pass, mate. I was 60 over 16 months ago and I don't get my bus pass until September. Maybe the spare seat in the donkey cart from Douglas to Peel already has your name on it, in which case good luck and happy birthday!
                      Neil
                      I don't suppose you could persuade the cox to bring Shannon up the Trent to Beeston Marina? I've just bought a new camera.
                      Edited By Dave Milbourn on 11/04/2013 08:40:03
                      #40209
                      Kimosubby Shipyards
                        @kimosubbyshipyards
                        Very jealous Neil – very.
                        Now hear she's not due here till Saturday at earliest, and then maybe not, just when we have a nice Irish Sea gale forecast too.
                        Dave, slightly different over here, once you hit the 60, all you have to do is fill out the form, available on-line, then take (yes take) in person to Douglas Sea Terminal complete with two photographs (so they can see its you) then wait a week for them to send back. Simple!
                        Hows the workshop? I got two new 1.5m LED tubes to replace old Hg ones, and all it says to do is remove and replace the starter with the supplied by-pass. Problem I have is there's the blasted ballast in there suppling power to both ends, whereas this tube is powered from one end. Oh, and no instructions either! The guy here just said "take it out."
                        Still, I'll enjoy tomorrow thank you, and see you on the circuit, Kimmo.
                        #40211
                          Have given up on waiting for the lighting panel mounting brackets to come from ROC – I think the donkey carrying them took a wrong turn at the lights in Istanbul. The guy who fitted the electrics is making me some from L-section ali, to my drawing, so we should be illuminated by about midsummer day! The LED panels have been here six weeks or so and they are superb. I just wish they weren't still in their boxes………
                            Posted by Dave Milbourn on 11/04/2013 08:39:27:
                            Kim
                            Neil
                            I don't think my influence will stretch that far dave……….but I did get a good recording of start up and running of her on my cam corder should anyone wish to download it to a sound system, nudge nudge, lol
                            #40216
                              Neil
                              If you can download the sounds as files then we can use them in most formats.
                              Kimosubby Shipyards
                                @kimosubbyshipyards
                                Hi Neil,
                                we now get the Shannon Sunday – yippee.
                                Kim
                                #40228
                                  Posted by Dave Milbourn on 11/04/2013 17:47:15:
                                  Neil
                                  the best I'll be able to do Dave being a technophobe is transfer it onto a vhs video, and then from there tape it onto a dvd/cdrom………anything after that and I'm totally lost, lol.
                                  hope you enjoy it Kim..she's lovely………..seats ain't arf bad either, lol
                                  Edited By neil howard-pritchard on 11/04/2013 21:16:52
                                  #40230
                                    Neil
                                    Whatever you can do I'm sure that the Collective can do summat with it.
                                    Kimosubby Shipyards
                                      @kimosubbyshipyards
                                      Neil,
                                      Shannon, force 9, Ramsey bay, AWESOME!!!
                                      Kim
                                      #40274
                                        any pic Kim???
                                        #40275
                                          Kim
                                          One of the many things that I miss about living on the Island is watching the sea come storming in and crashing over the Douglas sea wall.
                                          Happy days
                                          And of course there was always a quick sail to the mainland
                                          Edited By Paul T on 15/04/2013 07:20:41
                                          #40276
                                          Kimosubby Shipyards
                                            @kimosubbyshipyards
                                            Hi Paul,
                                            what scales's that Ben at?…………..just kidding……..it can get a bit lively on the crossing!
                                            Neil, loads in the harbour, though she went out in the Bay too far for my little camera. I'll collect a few up and send on CD if you PM me with an address – second cox, mechanic + 1 from Fleetwood say hi, they came over with her to IOM for a jolly, but went back on the Ben – lucky them – in the wind last night.
                                            Kim
                                            #40280
                                              Don't know who the plus 1 would be, but Steve Carroll is the 2nd Cox/mechanic….a reall nice chap……..mind you…….he races a large motorcycle for fun on track…….wonder what he does for relaxation, ……bungy jumping and sky diving I suppose, lol.
                                              Cheers Kim.
                                              No need to send me photos Kim…..as I got a hundred or so when she was over here……….but many thanks and appreciation for the offer……………just wait now for Speedline models to do all the hard work and bring a kit out…………and then I'll build Fleetwoods new boat WHEN she comes to port.
                                              #40281
                                              Kimosubby Shipyards
                                                @kimosubbyshipyards
                                                Neil,
                                                I've got the water jets already, from Dortmund, so am going to make a stab at the hull later this year if nothing forth coming from anyone. I do know that the hold up is not being given access to the lines and full drawings – seeing as its a true RNLI design I expect they're keeping a lid on as long as possible.
                                                Kim
                                                #40282
                                                janet farrer
                                                  @janetfarrer59583
                                                  thats a really nice model liked the mersey you had for sale but it sold where did your mersey end up going
                                                  #40283
                                                  janet farrer
                                                    @janetfarrer59583
                                                    hi
                                                    #40286
                                                    NormanT
                                                      @normant
                                                      This boat is now sold pending collection.
                                                      Norman
                                                      Colin: Is it possible to put this message after my original posting, please.
