here i was, thinking i had finished.
i had made the final piece in the puzzle..the triangular draw bar to attach the carriage to the tractor and attached it all……
so i decided to just see what it looked like with a boat sat on it….and so i decided to use Mick French's Mersey……………
Frenchie………i have a bone to pick with you!!!!
i put your mersey on to the carriage, and…………….
well all i can say is,there was a resounding CRAAACCKKK, AND i'm bloody glad i hadn't wasted my time and built a SLARS………because the whole bloody carriage collapsed under the weight of the boat……………
what an utter complete waste of bloody time……….So don't know whether to laugh or cry………at least i have a pattern should i want to rebuild it in 3mm plasticard at a later date………..but for now, i shall have a beer, a bar of Lindor chocolate and put it down to experience, lol
not to add insult to injury, i'd been out to Halfords this afternoon to buy some galvanised steel colour paint to paint the sodding thing with…………..bahhhh humbug!!!.
and so today, i scraped all of the glue off, reglued the wing on and left for a couple of hours……..
i will then drill and pin both sides with framing pins of about 0.5mm diameter……….and depending on how strong it seems…………..i'll try it out with some brass strip bracing to the thing………..if not, i'll switch to the main frame in timber and bond plastic to the insides of the framing and use 3mm plasticard to make the brackets.and glue with plumbers pipe weld.
