Hi David,
If you were to use shot then you wouldn’t need necessarily to mix it with the resin. The resin just goes on top to seal it in. If you are using sheet lead then, as suggested in an earlier post, cut it into manageable pieces and wedge it in and then again use resin to hold it in place. Also, with sheet lead, if you cut slices out to approximate the shape you need you can use a hammer to bash them together into a homogenous mass which should fit the cavity pretty closely.
Moulding it off the boat as you suggest would certainly be an alternative but would entail making a male plug from the cavity and then using this to make the female mould for casting which seems a lot of work for something that will never be seen.
If you do go down the moulding route then Google ‘melting lead’ and you will see lots of advice on methods and safety precautions on various angling sites.
Edited By Colin Bishop, Website Editor on 13/06/2010 14:15:17
