Have made progress particularly with the main deck structures and with the secondary armament, AA and range finders. The deck structures are entirely of styrene as I find this the easiest way of doing it. Having said that styrene for all its good qualities is a bit flimsy specially for large deck houses and as I do not want to use plastic of thickness greater than 1mm for weight purposes the deckhouses etc require a lot of reinforcement to prevent the occurrance of undesirable warping in walls and decks. This is just my method derived from my Deans Marine modelling experiences and not necessarily the best way of building but it works for me. As stated above I have done a lot of work on the secondary 15cm turrets, the dual triaxially stabilised 10.5cm Flak turrets, dual 3.7mm Flak mounts and single 2cm Flak mounts but I will leave these to later on.
Forward structure – one wall attached to supporting frame.
Forward structure – both sides attached. I have also triangular styrene pieces added to force the sides to remain square to the supporting frame. The small metal blocks are type face elements which are very useful for assembling styrene parts together for bonding.
Forward structure – complete and showing the supporting arrangements.
Forward structure – the top view. The square aperture is for the smoke (mist) generator flue to pass through.
Rear structure – partly built. The aircraft catapult and aft control centre sits on this deckhouse.
Aft control centre which has the aft main armament 10.5M rangefinder included. The rangefinder used as its basis the Fleetscale resin moulded part with some enhancement such as the rangefinder optics and the rods running parallel to the arms and he access ladder rungs.
Forward SL-4 Director mounted immediately forward of the main tower. This is an Flak director for use with the heavy 10.5cm Flak guns.This uses the Fleetscale resin moulded item with enhancements.
Forward armoured control tower with 7M secondary armament rangefinder mounted on top. The control tower has curved walls presumably to deflect incoming rounds but this does make it difficult to make. I made mine using a foam former which is easy to shape then bonding 0.25mm styrene sheet to it. Hopefully the blue interior of the control tower will not be a an issue after air brushing
Happy New Year everybody. Robin
