Flattening warped wood
Home Forums All things floating Flattening warped wood
  • #86843
    Zephyr Yachts
      @zephyryachts
      Hi,
      I am currently building an Aeronaut Clipper kit ( not much I know but it’s my first proper foray into kit building) and I have come across a small and relatively pathetic problem. The deck has been lined with small grooves which appears to have made the deck bend upwards longways. The main deck pretty much straightened itself when I glued the bulkheads in, but the hatch at the back to get to the rc bits is separate and still warped. What is the best way to flatten it out? I would think that steaming it and then putting it under a weight would work, but my family thinks otherwise.
      You seasoned boat builders probably know the best method naturally, but I am new to the art and haven’t worked with very thin wood very much.
      Thanks!
      Zephyr Yachts
        @zephyryachts
        #86847
          Zeph. Try the steam, eh? What have you got to lose!
            How about a hot iron on an ironing board and holding it straight for a few mins after?.
              If you can get it straight what I'd do if possible is then glue some pieces of timber, like mini-joists, to the underside to resist it bending. As the timber is thin it will probably be pulled flat again as you found with fixing to the bulkheads.
              Edited By Chris Fellows on 14/04/2020 22:18:29
              #86851
                sadly, as a teacher of woodwork for 25 years retired, you will never get it back to a workable condition, the timber has shrunk in the direction of grain, and there is basically nothing you can do, steaming soaking or otherwise, and tbh you will spend more time trying to straighten it than what it as a piece of timber is worth…….your best bet is just to cut the small loss, and buy a new piece of ply to fit and relieve your mind of the stress of trying to straighten for a few weeks only to lift the weight off it for it to spring back to the way it came originally…………..once a timber, solid ply or laminated has twisted, there is absolutely nothing that you can amend that nature has taken control of. sorry.
                #86852
                  Zeph
                  Could you post a picture please, of the offending warpage?
                  There may be a solution
                    Very true Neil. When doing woodwork at school a friend was making a table. He found a lovely piece of timber for the top but it was warped. He spent weeks and weeks planing it flat but it kept warping so gave up in the end.
                    As regards Zeph's problem though the offending ply is lined to match the deck. As Bob says a photograph is required. Another solution could be to glue a thicker piece is straight ply to the underside set back at the edges to allow the hatch to sit in place. Even if thin ply or other timber starts off flat it can curve anyway when varnish etc. Is applied and needs restraining in place.
                      Like Neil says your best route is to cut your losses and make a new hatch as you will spend longer trying to fix the old one and still end up with a twisted hatch.
                      Did you use a waterproof to refit the deck?
                      #86867
                      Zephyr Yachts
                        @zephyryachts
                        Hi guys,
                        All is well (at the moment); I glued some plywood reinforcements underneath the hatch and it is flat enough now.
                        thanks for the advice!
