Ooh yes Ashley WILL comment!
<p style=”text-align: left;”>Basically, most of my models use “the normal”…motor, coupling, shaft, esc, prop, servo, rvcr, tiller and rudder. So for a normal boat the costs are just about the same as anyone else’s. I do make my own rudder assemblies but that’s not a big saving in the grand scheme of things.</p>
Usually I use a cheap mini servo off ‘t Internet and they are very cheap. But a standard servo type is not expensive.
Big money is saved when you fo an air prop boat, as a prop is cheaper than a brass water prop (but not as cheap as an X or S two blader), however a brushless 28mm motor in 1000/1400 or 2200Kv with a forwards only esc can be had for u,nder £15…and it comes with a prop adaptor.
I do however not usually buy much in the way of fittings other than cowlings, but this rather reflects the lack of fine detail in my boats…
