Cutting Plasticard Advice
Home Forums Beginners Cutting Plasticard Advice
  • #93646
      From my builds so far I've gotten reasonably competent at building with timber but am now at a stage when I will shortly need to produce the window frames and later some other parts.
      I've bought some sheets of Plasticard in 0.5 and 1.00mm thicknesses but apart from knowing I will need something sharp I haven't got a clue!
      So an Idiots Guide would be very much appreciated covering the best tools and how to cut the frames out including curves. I assume that it's difficult to cut the frame straight out accurately, particularly the curves, and that some filing will be required? If so what are the best type of files?
      The more basic the better.
      Thanks, Chris
        David Marks 2
          @davidmarks2
          Chris – For cutting Plasticard you need a straight edge (steel rule) and a SHARP knife of you choice e.g. Swann-Morton. Score the material along the line of the cut which causes a weak point and the snap along the line. Thin Plasticard can be cut with scissors. Internal apertures can be formed by chain drilling and the filing out to size. Depending on the size of the piece files can be from 6 inch in length to needle files. I also used emery/abrasive sticks (nail files) used for trimming finger nails can also be used.
          #93651
          James Hill 5
            @jameshill5
            Chris- I agree with what David Marks has said and would add that you get yourself a cutting mat. They come in various sizes ,A4 for example and give you a good surface to cut on.
            I`ve used Plasticard a lot when building structures on my railway and find it a very easy material to work with and I intend to use it on the boat I`m trying to build at the moment . The glue I use when gluing plasticard together is Slaters Mek Pak, but there are others,
            Best of luck,
            Jim.
            #93653
              Thanks for the replies. The scoring and snapping is useful to know. I'll have to get myself a decent set of needle files.
                Hi Chris,
                I must admit to not liking Plasticard never much as the blade has a habit of skipping off and spoiling the work , as said by David scoring lightly and many passes works fine, Although I have needle files, it's just as easy to make your own with dowel and abrasive paper and contact adhesive, I use P120 & the finer grade P180 Hermes paper made in Austria from Axminster tools.
                This probably explains why I love working with ply down to 1/64th
                Are you window frames anodised aluminium of chrome plate on the real boats ??
                Snowing quite well this morning in Kent
                Edited By Ray Wood 2 on 07/02/2021 11:05:04
                #93657
                David Marks 2
                  @davidmarks2
                  Chris – Something to add. As with any cutting process you will end up with "burr" on the cut edge. With Plasticard the removal of the burr is very easy. A piece of metal e.g. the edge of a steel rule just drawn lightly along the edge and the burr just falls away.
                  #93659
                    I have couple of Linex Hobby cutting rulers, bought from Amazon, they have a non slip rubber pad underneath. One side for measuring and the other is thicker for cutting against. This helps to.prevent the knife blade skipping. They work for me. I bought a 50 cm one first, then a 30 cm one which I find easier to use on a work top. I use the cheap snap off blade knives and emery boards for filing the edges. Liquid poly for gluing.
                    Edited By Tim Cooper on 07/02/2021 12:35:00
                    #93664
                    Stephen Garrad
                      @stephengarrad28964
                      Chris,
                      The green cutting mats from "The Works", the cheapy book &craft shop are very good at £8-00 for 24"x18" or 600×450 if you prefer, the local Hobbycraft wanted £24 for the same size.
                      #93665
                        Thanks for the further replies and advice, much appreciated.
                        I've got everything needed, apart from a set of decent needle files, from what I've got for working with timber, so I'll have a bash now.
                        Ray, I don't know if they are chrome or aluminium but I'm going to try that Guild Lane Silver Chrome paint that the former editor used.
                        Dave Cooper 6
                          @davecooper6
                          With windows, I always drill /cut under-size then file to final shape. Bitter experience shows it's easier to remove material !
                          Scalpel blades can be re-sharpened on a grinding wheel /Dremel type tool. Although having a stock of new blades handy is a good policy I think. Buy quality needle files and they'll last for ever….I tend to use the flat, round and 'crescent' shaped ones mostly.
                          Happy modelling,
                          Peter Sykes
                            @petersykes47234
                            Posted by Chris Fellows on 07/02/2021 17:45:35:
                            Hi Chris,
                            I've built scale models for years and the best "metallic" Chrome / Silver / Aluminium paint I ever found is the ALCLAD range. VAllejo are really good as well. But whatever you choose make sure you clean off the plasticard with some IPA and prime it first..
                            Peter
                            Edited By Peter Sykes on 08/02/2021 13:20:21
                            Edited By Peter Sykes on 08/02/2021 13:21:02
