It's surprising how much a different prop can affect a boat, even if the different prop is nominally the same. If you can, get a selection of props and see what the difference is.
I thought apart from the amperage , all nihm batteries were the same….
It would be truer to say that all batteries are different!
Conceptually, a battery is two dissimilar plates with an electrolyte between them. In a simple battery. the electrons initially flow easily between the plates, but then they gradually slow down as the chemical close to each plate becomes locally depleted – this is called 'polarisation'. Leave the battery for a while and it will recover.
Modern batteries address this problem with clever chemical mixes, and clever internal physical organisation, optimised for the job the battery has to do – typically either long slow power delivery or short fast power delivery. The ability to accept fast recharging is also designed in, or not, depending on the battery. As are other features. So even batteries which use the same basic internal chemistry may have different characteristics, depending on their design…
