Are the props to big
Home Forums Building Kits Are the props to big
  • #6115
    Andy Hustler
      @andyhustler32076
      Andy Hustler
        @andyhustler32076
        I am replacin the props and shafts on my Italeria E Boat and am not sure if the props i got are to big for the boat or are they the right size or not . Do i need smaller props or wil these be ok for the job ??
        #41555
          Give us a clue, Andy……………..
          #41558
          wayne quigley
            @waynequigley28540
            what size have you got
            #41560
            Andy Hustler
              @andyhustler32076
              Hi all the props in the kit are 40mm and the replacement are also 40mm from Radio Active and i got them for £1.00 each and the guy behind the counter in Antics said they were wrongly priced and should of been £1.90 each but i got them for the marked price !!! I have also invested in an Expo product which i can only describe as an allen key mounted in a screw driver a very usefull bit of kit that i wish i had invested in along time ago .
              My plan is to open up the 2 outer shafts and block the centre one , but i am not sure about the rudders as i am keeping the ones in the kit and am not sure if i need to make them a bit bigger or keep them the same size and see how it goes on the water .Any advice will as always be most gratefully appreciated .
              Andy
