What size ??
What size ??
Home Forums Building Kits What size ??
  • #58810
    Andy Hustler
      @andyhustler32076
      What size motor would be suitable for the Revel Snowberry ????
      Andy Hustler
        @andyhustler32076
        #58812
          A 385 my guess.more than enough for pottering about. Run it on 6 or 7.2V. Nice little motor.
          No doubt someone will post with a difinitive answer soon as there have been thousands built.
          Charles Oates
            @charlesoates31738
            Mine has a 385 on 6 volts. More than enough speed. I usualy run no more than 3/4 speed, the reserve is handy when I mess up my navigation.
            #58828
              I used a 385 on 7.2 volts with a 40mm 3 blade plastic prop. Always runs well.
              Stan Smith
                @stansmith75814
                On Snowberry (converted) what length of propshaft has been used – have just finished the Italeri MTB and Snowberry is to be my next project. All the conversion articles I've read don't give shaft length. Many thanks
                #59389
                  A late member of the ModelBoatMayhem website successfully used the following:
                  Deans Marine Kyte motor
                  6" prop shaft with oil filler
                  3 bladed 35mm brass prop
                  Marine 5 speed controller
                  7.2v nicad battery pack.
                  Universal prop shaft coupling
                  Existing kit rudder bonded to smaller rudder with resin
                  Futaba 2 channel radio.
                  Stan Smith
                    @stansmith75814
                    Thanks Colin, that's extremely helpful – will make a start on getting the gear together with some of the GLS aftermarket extras.
                    Again many thanks for such a prompt reply
                    Stan
                    #59395
                      Good luck with the build Stan, keep us updated.
                      I assume you have already seen Dave Abbot's review:
                      Stan Smith
                        @stansmith75814
                        Thanks Colin – had skimmed it awhile back but at the time wasn't thinking about doing a Flower let alone converting one – will now re-read thoroughly
                        Cheers again
                        Stan
