Vintage Gentleman’s Cruiser
Viewing 25 posts - 1,501 through 1,525 (of 2,420 total)
  • #57319
      Hi chaps
      Pleased to report that Lady Jane has successfully run on all four motors with no problems whatsoever!
      When running, the whole drive system has the aura of latent power………As originally intended
      Note……No Rc wires have been cut
      Edited By Bob Abell on 18/04/2015 15:26:38
        Photos?
        #57324
          Hello Paul
          No photos at the moment, as there is no change in appearance from the last float test
          Today we had a good demo, for brother Geoff and his wife, running all four motors and it was awsome!
          The speed seems very fast, probably because of the smallness of the pond and it dashed into the pool wall with no sign of amp overload etc
          There could be a Timimg belt tooth mis match at the moment, highlighted by Geoff, but will be sorted shortly
          The visitors were very impressed with the initial appearance and size of the model and the multi motor spectacle
          I am truly proud of our team effort
            Hello Captain Bob
            It sounds like you had a wonderful time this afternoon.
            I am really looking forward to seeing the boat on Etherow as I have high hopes for the hull and its 'smoothness' as it glides through the water.
              Bob. Good stuff. after 151 post pages!! Glad to hear the motors and so on work ok.
              What is the final current draw for all 4 motors??
              The BEC thing..I suppose that as it is all is ok, then leave well alone..however if you do get problems you will have to start cutting wires.
                Thank you, Ashley
                The secret of my success is that there is no overall draw on the motors……That's why I couldn't understand Paul's request for this reading
                The Max amps is what the tests showed last week………17 amps when pushing against the pool wall
                As simple as that!
                mike farrell
                  @mikefarrell21522
                  Hi Bob ,For what its worth after seeing the motors demo at Ellesmere Port I had no doubt all would be well (exempt duff batteries).Still it will be great to see her showing off on the water . Between you both a beautiful creation will grace Haydock winkWell done.Michael
                  #57333
                    Many thanks, Michael
                    Hoping to post a video of the four motors, shortly
                    It reminds me of the old Ariel Square Four!
                      But a lot easier to start smile
                      #57351
                        Coming soon to screen near you!
                        All action video directed by Duckie and Pepe
                        Outside broadcast……Starring………. Bob Abell of BBC Coast fame and The very controversial multi engined Vintage Gentleman's Cruiser……Lady Joyce
                        Designed by Paul Thomason
                        Filmed on location at Coniston Pool
                          At last……On Coniston Pool……..The video
                          Many thanks to Duckie and Pepe
                          Captain Bob
                          ChrisB
                            @chrisb29081
                            Bob, looks excellent. Has the look of hidden amounts of power! Almost menace.💪
                            I think though you missed a trick with your pool, you could have used an inflatable boat as your pool, then you could empty it and use it as a rescue boat ( if needed). 😜😄🚣
                              Thanks ChrisB…..Pleased that you like the video
                              It was like a caged Sea-lion, trying to get out!
                              Will be doing another video shortly, when the electric panel is tarted up and with the cabin on too
                              Thanks for your post
                                Hello Bob
                                Nice to watch but who was the guy in the braces?
                                CookieOld
                                  @cookieold
                                  Bloody hell Bob it sounds like 4 merlins in a Lancaster on the dry run.
                                    Hello Cookie
                                    It sounds really awesome inside the garage!
                                    The pool has really been a great help in sorting the motor drives out, we would really have struggled on the big lake
                                      The chap in the braces, looking rather slim…..Ahem!
                                      Is Fred Dibnah`s stunt man!
                                        The pool test was most impressive Bob and Paul.
                                        #57363
                                          Hello Tony
                                          We are pleased you liked the demonstration
                                          Actually, Paul can't get down at the moment, he has a transport problem
                                          When the time eventually arrives for a real sail at Etherow, he'll probably walk it!
                                          Bob and Paul
                                          #57364
                                          Banjoman
                                            @banjoman
                                            A very impressive test session indeed — thanks for posting the video! And congratulations on the excellent results!
                                            And that chap in the braces: not only Fred Dibnah's stunt man, but his voice double, too, I'd ha' said …
                                            /Mattias
                                            #57365
                                              Video notes
                                              The knocking noise was caused by the propellors, driving forwards and backwards along the prop tube!
                                              It's not a problem, just need to fit two spacers
                                              One of the rudders was a bit slack on the rudder post……We were trying to perform a tank spin, but the water thrust kept pushing the rudder blade away
                                              The pool is very handy for tinkering close to the garage facility for instant adjustment
                                                Hello Banjo…….Thanks for looking in!
                                                So you know, my mate, Fred?
                                                I've always admired his "Rough and ready" attitude to life and share most his interests, but couldn't possibly climb a chimney!
                                                Did you see me on the BBC Coast program, with my Great Eastern model?
                                                Quite a few viewers noticed the close similarity to Fred Dibnah………"You're doing a good job!"…….He said
                                                Look out for it……Coast Series 7……Atlantic Cable Laying
                                                All good fun….eh?………Ee'…..Bah gum!…….Don't ask me, what it means!
                                                  bob. motors…fantastic, truly fantastic, worth the effort. Possible overkill on the ESc front…. and what a promising likely speed showing for the boat. Should be really great…a great build and how big !.
                                                    Hello Ashley
                                                    Thank you, pleased you like the demo
                                                    It does appear to have good potential for fun on the water…….Great relief!
                                                    I agree, the ESC`s look comfortabell!
                                                    I really need to finish off the cabin cosmetics, before the public sail
                                                    Banjoman
                                                      @banjoman
                                                      Hello Bob,
                                                      I did indeed see you and your Great Eastern doi9ng cable laying when the show was first broadcast — Coast is a programme that my wife and I enjoy in general, and thus usually watch, so I was of course absolutely delighted when that particular episode included a nice, long item built around a really lovely model.
                                                      We also both appreciate Brunel's work, and took great pleasure in visting both the SS Great Britain and the Clifton suspension bridge when we were in Bristol a few years ago, so the fact that your Coast item was about a Brunel ship added yet more to our delight
                                                      And while I never knew Fred Dibnah, in the sense of coming face to face with him or making his aquaintance, I certainly know of him, and have always thoroughly enjoyed his work for TV, ever since I first saw him in what I think must have been a re-run of The Fred Dibnah Story sometime in the late 1990s …
                                                      /Mattias
                                                      Edited By Banjoman on 21/04/2015 14:45:00
