Tx problems
Tx problems
Home Forums R/C & Accessories Tx problems
  • #121005
    Roger Fuge
      @rogerfuge
      Both my aging Specktrum  TX  radios are playing up thinking of replacing with Flysky  do
      anyone have any thoughts
      Len Morris 2
        @lenmorris2
        Hi Roger,
        My recent purchase was a 6 channel Microzone set (TX&RX) from Howes for mi Puffer.
        Inexpensive at 39 pounds and it worked a treat.
        Len.
        #121014
          I think with all these manufacturers you have to compare like for like.  Depending on the Flysky model and the Spektrum model, if you compare transmitters with equal specifications I suspect there is little to choose between them.  I use Spektrum for the flexibility.  I have a Dx6e, which can store up to 200 models, so I use it for boats, lorries, cars and even an aircraft.  If there is a similar specified Flysky model I’m sure there won’t be much to choose between them.  I do like Spektrum quality though and have never had a failure after using the Dx6i and the Dx6e for around 20 years.
          #121018
          Roger Fuge
            @rogerfuge
            Thank you every one for your response  it certainly gives me food for thought , the problem is one spektrum  has no signal on left rudder been told this is a known problem and the other radio when using memory 4 on tx I lose the signal intermittently  but all other model memory works fine
            #121021
            Dave Reed
              @davereed72029
              Hi Roger,
              Not sure which Flysky you were considering, but I have the Flysky FS-i6X and get on OK with it. Here’s the basics:
              6 channels – can be upgraded to 10 with a free firmware update (some come with it already installed). The cable to do the update came with mine but may not come with all of them.
              Firmware update cable can also be used to connect transmitter to PC flight simulators that support it.
              Comes by default with ratchet throttle. A self centering kit is available which I fitted to mine
              The instruction manual is not the best. If you want to more than basic setup (differential thrust mixing for example) your best bet is youtube videos.
              The first 4 channels are on the usual sticks, the others can be assigned to 2 variables, 3 two position switches and 1 three position switch.
              I recently discovered that if you select the right 2 receivers, you can assign them both to 1 model at the same time. Control landing craft and landed vehicle without changing transmitters maybe? I can check which 2 receivers worked together if anyone interested.
              By the way, you may need to change all your receivers if you change transmitter brand.
              Hope that helps
              Roger Fuge
                @rogerfuge
                Thanks for the info just what a I wanted to know could you tell me how many models can it support
                many thanks again
                #121026
                Dave Reed
                  @davereed72029
                  FXi6X supports 20 models
                  #121028
                  Dave Reed
                    @davereed72029
                    By the way, you can download the manual and firmware update from Flysky
                    https://www.flysky-cn.com/i6x-xiazai-1
                    #121030
                    Roger Fuge
                      @rogerfuge
                      Thank you Dave   I will investigate a bit more
                      #122565
                      cheddar24man
                        @cheddar24man
                        FlySky you get a lot for your money and certainly adequate for running a boat.
                        I have the FS-i6 and have been flying gliders for years with it and never had any issues.
                        #122896
                        cheddar24man
                          @cheddar24man
                          Modifying the FS-i6 for boat control – left stick self centring – £3 kit from Howes hobby.
                          Bit fiddly as most of the components are tiny, but quite doable.
                          Works a treat.IMG_3131
