Twin Brushless
Twin Brushless
Home Forums Beginners Twin Brushless
  • #117400
    Nigel Taily 1
      @nigeltaily1
      I want to put 2x brushless in my Huntsman. I plan to only use 1 ESC.
      Can I get 1 of the motors to run counter-clockwise while the other runs clockwise?
      it was easy with the brushed motors as I simply swapped black for red.
      Does that work with brushless?
      Thanks
      Dave Reed
        @davereed72029
        Hi Nigel,
        More knowledgeable people will be able to give more detail but basically you need to have 1 brushless ESC for each brushless motor, in your case 2 ESC’s and 2 motors.
        They can be connected to the same receiver channel with a ‘Y’ cable if desired. To reverse direction of spin simply swap 2 of the 3 wires between ESC and motor.
        When using 2 ESC’s you should remove the +ve wire from one ESC to prevent them both trying to provide power to the receiver.
        Dave Reed
          @davereed72029
          There is an article on this site that gives more detail on brushless motors.
          Going brushless?
          #117409
          Nigel Taily 1
            @nigeltaily1
            Thankyou Dave,
            That was what I wanted!
            Now its really clear.
            Many thanks,
            Nigel
