Transport Trolley
Transport Trolley
Home Forums Scratch build Transport Trolley
Viewing 25 posts - 101 through 125 (of 143 total)
  • #58982
      Hello Gareth and Andy
      You were not supposed to pick that up but I am oddly pleased that you follow my scribbling so avidly.
      All I can say is this is the problem with arguing against Bob when I can only present limited information.(I drop the ball) and end up with egg on my face.
      What I can say in my defence is that the lifting rig does rotate in relation to the base and the crane itself can be mounted on either side of the trolley depending upon the weight and size of the load.
      Sorry for the cloak and dagger double talk but all will be revealed at the appropriate time.
        A plan view showing lifting sequence for a 4ft+ boat
        Head scratching is optional wink
        #59035
          It would be more understandable, if you showed the water's edge
          And where the man stands
            Yes Bob it would be
            #59041
              I'm no genius but I would hazard a guess – and I may have got it horribly wrong, here, Bob – but I reckon that, in the last little picture, the water is somewhere underneath the boat while the trolley remains firmly on the bank. That would place the water's edge somewhere in between. The man is standing at the end of the control wire with the controller in his hand (probably the left right hand). I've drawn a small "map" of this to help you. I'm sure Paul will tell me if I've got it wrong……
              Edited By Dave Milbourn on 11/07/2015 09:57:05
              #59042
                Hi Dave
                Yes that's exactly right and thank you for showing me as being super slim.
                But now I have to figure out the wiring for all of these motors.
                  If you look very closely you'll see I've also given you blue eyes. Bob's your man for wiring up multiple motors. Just keep your grub-screws tight, dude.
                    I'm sure you realise…..All the weight is on the front pair of wheels?
                      Could you please explain exactly what you mean by this, Bob, as well as explaining why it should be significant? Us non-engineering Kevins are a bit slow on the uptake sometimes.
                        Because, the hub assemblies are so feeble, Paul had to fit three pairs!
                        Thinking erroneously, that all the weight would be shared!………Alas…….No
                        I did mention a solution, but Paul, pooh poohed the idea
                        Come in, Paul
                          The trolley davit is based upon mobile cranes, of which I have many years experience.
                          The body of the trolley acts as the counterweight for the load, the six wheels are sharing the load of the trolley and load (that's why I have specified six wheels instead of four) far from being feeble the hub assemblies are very strong as the shafts are constructed from 12mm chrome steel.
                          Your solution of outriggers wouldn't work as all that they would do is position the body further away from the water.
                          So the hubs are not feeble
                          The weight is correctly shared over all six wheel
                          Outrigger supports (jack legs) wont work.
                          Over to you Bob
                          Paul wink
                          #59057
                            Sorry Paul
                            The front pair of wheels act as a pivot…..The other four wheels support nothing but fresh air!
                            Out riggers are your only answer
                              When a 50t mobile crane does a 'pick and carry' operation why doesn't it tip up?
                              Have a read about pick and carry and you will see what I mean.
                                Thank you, Paul
                                I have no need to view the Pick and Carry cranes
                                Let us say no more about the matter and just wait and see the results of your labour?
                                  Dear Kevin
                                  I would like to explain that during this conversation Bob has been playing devils advocate by asking some very pertinent questions.
                                  Bob has asked these questions in his usual down to earth manner and in doing so has demonstrated that I haven't provided sufficient technical details.
                                  Its no good me saying that the design is correct if I haven't supplied drawings to support my claims so I will rectify this over the next few days
                                  Thank you Bob
                                    Thank you, Paul……Very gentlemanly of you
                                    Paul has cleared up the situation by adding ballast at the rear of the trolley
                                    "That was a near run thing!"…….As Wellington, once said
                                      If the trolley has to be counterbalanced to compensate for the load then a significant weight of ballast must be carried on the trolley. One more thing to go in the car unless it's a water tank filled from the pond?
                                        Hello Colin
                                        You are correct about a significant weight especially with larger boats, I had considered using water as the counter weight but water doesn't have the required mass so I opted for lead acid batteries.
                                        The batteries can be carried separately during transport and fitted into the trolley in the car park, the number of batteries needed depends upon the weight of the model being carried.
                                          I don't see why you should feel the need to, Paul. You are a qualified engineer with a lot of relevant experience and if you are satisfied that something is correct then I, for one, wouldn't argue with you – especially in such a truculent manner. Whether or not the trolley works in the way you intend it to (or overbalances etc) should depend on the decisions and calculations which you make – not on some snug-bar speculation offered by the usual suspect. In your position I would never invite public contributions to my design process; that way you end up doing at least twice as much work in getting to the same result.
                                          Please yourself, m'duck – at least one person will be happy!
                                            I understand your comments and in my past life I wouldn't entertain any non-relevant questions and I would only seek council from people with equal experience and knowledge. In my profession I had to make tough decisions on a daily basis and couldn't / wouldn't have the time or feel the need to discuss these decisions with the tradesmen or labourers that worked on the site.
                                            However when I started this boat design lark I had to take into account the fact that having little experience in designing model boats I didn't feel able to approach professional model boat designers such as yourself for advice and, due to medical problems, I am a slow builder so a build blog could be a slow and boring thread.
                                            Bob came to my rescue when I asked for a builder who was willing to undertake a 'warts and all' build thread with one of my untested designs, there aren't many model builders who would be willing to risk their reputation in this way and for this I will be eternally grateful to Bob.
                                            The partnership also included a requirement on Bobs behalf to ask awkward questions on behalf of the many Kevins that follow his builds.
                                            Our arrangement has been quite successful through the Ellie and Brutus builds
                                            I don't know what the future holds and I have no doubt that Bob and I will be chatting about it when we meet up at Haydock.
                                              As a Kevin, I have been following Bobs/Pauls builds and on the odd occaision asking the devils advocate questions as one must to keep them on their toes.
                                              As there is no right or wrong way to make a trolley like this i have not added much input yet. It is of course up to the whims of the bulder as to whats suitable.
                                              Ashley devil usual disclaimer
                                              #59086
                                                whims of the bulder ?
                                                whims ?????
                                                crying 2
                                                #59087
                                                CookieOld
                                                  @cookieold
                                                  Hi Paul , You and Bob are a credit to the world of model boat building and long may it continue ,i like reading your threads and 99% of the time i learn from them . Only when a part of the build is in my field ( Mechanical Engineering) do i have the confidence to comment and only if i think my comments will help the build.
                                                  Best regards Davewink
                                                  #59088
                                                    Hi Cookie
                                                    We are all learning and we only advance by asking questions, I stand by the adage that there is no such thing as a silly question…even when its from Bob.. lol
                                                    I wish that more people would ask questions as they would receive a straight answer and wouldn't be treated like a fool.
                                                    I can say that without the banter my charity fundraising wouldn't have got off the ground.
                                                      There's nothing wrong with asking a question; that's what this forum is for. It's only a silly question if you've already asked it once and had a reply. Neither is there anything wrong with playing devil's advocate, Ashley – but there are ways of doing it which, thankfully, most people are aware of and abide by. The problems only arise when they don't.
                                                      Before they hit the Enter key to send their latest jibe on its way, there are certain folk who might bear in mind that there is a fine line between being 'forthright' and just downright rude. Show some respect and you'll have it shown to you.
