SLO-Mo-Shun IV 520 R/C set up
Home Forums R/C & Accessories SLO-Mo-Shun IV 520 R/C set up
  • #99242
    John Logan 1
      @johnlogan1
      Can any one recommend current motor, coupling, servo, speed controller, battery R/C controller
      for Billings wood model I’m building.
      Kit didn’t include specs or anything
      John Logan 1
        @johnlogan1
        Parts needed
        #99259
        gecon
          @gecon
          Doesn't seem like the 'expertise' exists here, but If you google 'building the Billings slo mo shun' a few threads appear. I'm sure you'll find some reference to power trains. Don't know if they will help much though, you'll have be the judge of that. I assume you want more guff and less weight that the original Speed 600/700 and Ni-Cads shown on the plan.
          George
          #99260
            John. Welcome to the forum! A quick search shows a number of builds on the old internet, didn’t look hard, I presume some of the must detail what gear they used.
            For something like this, a fast boat, you will likely want a brushless motor, so a 35mm one say 1400-ish Kv might do on a LiPo battery, 3s.
            The combinations are unfortunately endless and no one setup is “right”. I don’t know how big or heavy it is, but even 28mm motors at 200 watts and 1450 ish Kv might also be ok. Bearing in mind a 600/700 motor (generally) puts out nothing like 200 watts and a 28mm motor is 1/4 the weight.
            Aircraft esc are ok if you don’t want reverse, current rating to overmatch the motor max rating by 50% or so would be suitable, or use a car reversing brushless one, Ora pukka marine esc.
            Any servo will do. Standard ones or small ones.
              Just had a better read of some of the build threads..not all…
              Mostly they major on the actualbuild and not the power train.
              At least one had good performance on a speed 600 , but one said, after using this motor, that a brushless 400 would have been better.
              If you fitted a 35mm brushless motor on a screw-on mount, it would be very easy to change the motor for something more revvy or powerful .
              Coupling…the plastic u/j style of couplings should be ok unless you get a really serious motor. Other than a solid coupling I have not used anything else.
              Sorry, nothing definitive. Harry will likely chip in as he has more fast brushless experience.
                Hi John and Ashley
                CHIP, CHIP !!!
                I recommend a Banggood Surpass Hobby C 3542-1450kv with a 100Amp ESC for up to 4S Lipo battery.
                These are rated at 1050 Watts on 4S @21,480 rpm no load.
                They have a 5mm shaft and are a good strong motor.
                Same mount as a 540 brush motor.
                Prop start with a 35mm surface one and may be move up to 40mm later.
                Coupling Banggood have stainless steel ones with grub screws which handle the power.
                #99596
                Former Member
                  @formermember67585
