This evening I managed a little more on the frames. I managed to remove most of the glued template paper at the weekend and the rest tonight.
I had to sand a few of the location slots to get the frames to fit, and I am now quite happy with the results. So that's a big thank you to all the chaps who have offered advice so far. I am going to have a go at glueing them all in place soon and I intend using some Gorrila glue. Will this be strong enough?
I have asked at work for any round bar off cuts to be saved so I can make some weights to place against the frames to hold them square whilst they set. Unless anyone can advise on a easier method. Turning the bar ends square will not be a problem for me.
The cut outs in the middle of the formers was done on my milling machine as described earlier, however this left a rough cut. To clean it up I used this:-
It removes wood very easily so I was very careful.
I am very happy with the fit, I was very careful when I cut then out sticking to the outside of the printed lines. Normally I tend to rush and make a b-/::;r of things. So for me this is quite good.
Now that I am at this stage I need to re read the MB mags and check what material is used for the long frame sides, I have plenty of balsa wood but I think it should be spruce. I will read the mags and check.
Happy modelling, Brian
Edited By Brian Dickinson 1 on 31/08/2017 20:13:59
