Scratch Building A Hull
Home Forums Beginners Scratch Building A Hull
  • #9989
    daz bruce
      @dazbruce16150
      i want to build a bait boat for fishing and would like some advice on building it i have motors and servos i am quite handy at building so i am confident in building my project all help would be very appreciated thanks daz
      Tony Bailey
        @tonybailey66542
        Dear Sir,
        Could you please help me, i am new to boat building and have a billings boat 586 with twin rudders. I am unsure about how to attach the rudders to the single servo or if i have all the right pieces to do it.
        Any info would be most appreciated.
        Tony Bailey
        #10012
        ARH
          @arh
          like this.<div align=’center’>
          </div>
          #10032
          RAAArtyGunner
            @raaartygunner
            That is the type of help we need.
            Well done.
            #10051
            Charles Oates
              @charlesoates31738
              Yep that’s the way to do it. If you don’t like bending metal, many people use the pins from a 13 amp plug. It’s best to file down the ends somewhat before drilling a hole for the servo conection. They make great tiller arms for any setup.
              #10074
              merlin
                @merlin
                If middle position doesn’t suit move arm through 180 deg it will work just as well on either side. Servo does not have to be close to rudder use a flexible connector (it is called a snake I believe)
                You should try to dictate where things go if possible not the model,make future maintenance EASY!
                #1324
                daz bruce
                  @dazbruce16150
