Hi All
I was ask about replacing the Graupner speed 600's in a two engine boat with a lighter brushless setup.
The boat is stern heavy with 5000mah Metal NiCad in the stern.
This is the only space for the battery.
As the Graupners are about the 19000 rpm and are about 192 grams each.
The replacement Graupner motor is about $70 AU each and I can only get one.
I have moved some of the other electrical stuff forward, but, I am trying to not add more weight.
So plan A is two D3530/8 1700kv brushless motors (74 grams each) 430watts from Banggood($26.91 each), a Zippy Compact 3S 3300MAH 60C(288 grams) for Hobbyking and a pair of car ESC 45 Amp (69grams).
What is your guys ideas, please??
