RAF boat ID and infoplease…
Home Forums Scratch build RAF boat ID and infoplease…
Viewing 25 posts - 1 through 25 (of 34 total)
  • #7131
    Martin Field 1
      @martinfield1
      Martin Field 1
        @martinfield1
        Hi, I have discovered in my searches for info on my crash tender two boats that I would love to do models of. They are an old boat seen in Basrah, number 153 and the Mk 1 37'-6" fire float.
        Are there any drawings for either, what colour are the light coloured ones and what is in the open cockpit areas?
        What general shaped hull is No. 153.? What length?
        I don't know how to put pictures on here since photobucket's self destruction.
        Martin
        Edited By Martin Field 1 on 07/06/2018 11:37:44
        #77393
          Hi Martin
          Check out this site **LINK**
          Harry Smith
          #77394
            Mk1 Fire Float
            37.5ft Fire Float Mk.I
            RAF NUMBERS FT1 – FT36, FT40
            Builder British Power Boat Co, Hythe
            DISPLACEMENT 5.0 Tons
            HULL DIMENSIONS LOA………37' 6"
            Beam…….8' 6"
            Draught….2' 6"
            HULL PLANKING Material……..Mahogany
            Method…….Single (Sides)- Double Diagonal (Bottom)
            Side Thickness…..5/8in
            Bottom Thickness…3/4in
            MAIN PROPULSION Twin Meadows 100 bhp
            GEARBOX Meadows
            REDUCTI1ON Direct
            DYNAMO CAV Bosch 24 Volt
            AUXILIARY MACHINERY Coventery Climax F.F. 75bhp
            FIRE PUMP Coventery Climax F.F. 500 galls/min
            PROPELLOR Material . . . Manganese Bronze
            Pitch. . . . . .13"
            Diameter . .14"
            Hand . . . . . .Right Hand
            TAILSHAFT Material. . . .Monel Metal
            Diameter . . .1"
            MAXIMUM SPEED 20 Knots
            TOTAL FUEL CARRIED 65 Gallons
            #77395
              70ft Aero-Marine High Speed Launch
              RAF Numbers 150-155
              Builder AERO-MARINE-CRAFTS Ltd, Trenton, Canada
              Displacement Not Listed
              Dimensions LOA………70' 0"
              Beam…….15' 0"
              Draught….4' 2.5"
              Construction Double Diagonal
              Material Phillipine Mahogany
              Main Propulsion Triple Liberty Conversion 12-cyl
              each 500 bhp @ 2000 rpm
              Reduction Centre engine Direct, Wing engines Vee drive
              Maximum Speed 44-45 Knots
              Max Cruising Speed 27-30 Knots
              Duration @ Maximum RPM 30 minutes
              Total Fuel Carried 2500 Gallons, 100 octane petrol in 5 tanks
              Range 350 miles @ Max continuous speed
              420 miles @ Cruising speed
              Complement 13
              Radar Type 286, later Type 291
              Armament (On Transfer to RAF) 1 x 20mm Oerlikon (Aft)
              2 x Twin 0.5" Vickers (Abreast Whelhouse)
              1 x Lightweight 20mm (Foredeck)
              #77396
                Martin Field 1
                  @martinfield1
                  Harry, many thanks for your help. Alas the 150 you've mentioned there is a huge 70 footer, whereas my 153 is a tiddler. Has the look of an American Chris-Craft Red and White "rum runner", I'm guessing around 32 feet, high prow, open rear cockpit, light colour as you would expect as it's photographed at Basrah. The Mk1 stuff I found on that excellent website you mention and am trying to find what a Coventry Climax FF pump looks like. I can find pics of the encased and wheeled pump, the sort towed by taxis during the War, but nothing on a boat based frame. I'm assuming it was a sidevalve engine, but 75 HP was quite something for pre War engines. My CC book only covers the racing engines, a different branch of interests for my over worked brain.
                  Is there a description of how to put pictures up here?
                  Cheers,
                  Martin
                  #77411
                  Mark Jarvis 2
                    @markjarvis2
                    Hi Martin, the pump would have been fitted in the engine room, so would not be visible from the outer hull. Pictures are very rare, some books show b&w photos but are not clear.
                    Mark
                    #77414
                    Martin Field 1
                      @martinfield1
                      Hi Mark,
                      surprisingly, perhaps, the engines are out in the open under a casing each side and the pump is an encased jobby, like the towed ones on land and that is in the bit that looks like a cabin. I have found a photo on the site referred to above. The back of the "cabin" is open.
                      Still nothing on the smaller boat 153.
                      If someone will explain putting photos on here I will put a couple up.
                      Cheers,
                      Martin
                      #77415
                        Martin – you add photos to an album first, see grey menu bar at top of page, and then when posting click the little camera icon at the top of the box you are typing in and choose photos from your album.
                        Edited By Chris Fellows on 08/06/2018 09:41:01
                        #77416
                        Martin Field 1
                          @martinfield1
                          Thanks, Chris.
                          I now have an album.
                          So here are the pics of the two boats I'm interested in and the all important one of the engine and pump in the Mk1, 37'-6".
                          Nope, only got one picture although I put 3 in.
                          Keep trying.
                          Martin
                          #77417
                          Martin Field 1
                            @martinfield1
                            Next one…
                            The innards of the Mk 1. Meadows 6 in a casing either side and Coventry Climax FF pump in the open backed "cabin".
                            Martin
                            #77418
                            Martin Field 1
                              @martinfield1
                              And finally, folks….
                              The Mk 1 37'-6".
                              Sweet shaped boat.
                              Nope, it's in the album, but it won't appear. Don't know what to do with it.
                              Martin
                              #77421
                                Hi Martin
                                If you click onto the camera on your post(second from the end) you can add one photo at a time.
                                If you google Coventry Climax FF pump you will pictures of a number of them.
                                If you use MWSnap(free program) you can capture screen shots and save them.
                                Using a paint program cut and resize to you requires.
                                #77424
                                Martin Field 1
                                  @martinfield1
                                  Really? Let's try it. I can't do all the download and use stuff. Never works and screen shots, etc.? All beyond me.
                                  Tried the camera click and got (in text) one of my 3 pictures, that I already showed.
                                  Is that pump a definite FF? I also googled it but all you see is cases, no proof of it being the 75HP, which really was quite powerful for pre-War. But the cases all look similar anyway.
                                  Cheers,
                                  Martin
                                  #77425
                                  Martin Field 1
                                    @martinfield1
                                    If you look on albums, under RAF boats, you might see 3 pictures that i put on the album, but when I click on the camera, all it offers me is one picture.
                                    Cheers,
                                    Martin
                                    #77427
                                      #77429
                                      Martin Field 1
                                        @martinfield1
                                        That's the one Harry, thanks. I couldn't get the top one to appear.
                                        Anyway, now we have them, does anyone know of any plans for the Mk 1 above? I very much doubt if there are any for the 153 boat, but I'd love to know if anyone has any clue what the hull might resemble so I could make a stab at it.
                                        Cheers,
                                        Martin
                                        #77442
                                        Martin Field 1
                                          @martinfield1
                                          Can anyone identify what the three apparent pipes are on the starb'd side next to the pump? And would that box affair on the port side be perhaps a battery box? I take it the slatted affair on the roof is for lashing stuff to?
                                          Cheers,
                                          Martin
                                          #77449
                                            Hello Martin
                                            The two boats are both RAF Seaplane Tenders, the FT1 is a common type and has obviously been adapted as a fire boat the other (135) looks like a Brooke from the early 1920s.
                                            The background and officers uniforms in the 135 picture lead me to think that the boat is on the Nile and probably used to service the large Flying Boat scheduled flights.
                                            Image result for raf seaplane tender
                                            yacht
                                            The 'box' could be a simple seat/tool chest for the pump operator.
                                            I can't make out the three pipes on the stb side that you refer to.
                                            Hope this helps
                                            Martin Field 1
                                              @martinfield1
                                              Paul,
                                              many thanks. I was thinking Brooke too as it looked like a slightly bigger version of a Brooke that we saw at a Windermere rally of the CMBA a few years ago.
                                              The Mk 1 in your pics is, I would say a slightly longer version and its windows are a different shape, but generally a similar craft.
                                              The three pipes are running for and aft on the inside of the starboard wall of the open cabin and have a shadow falling on them.
                                              The 153 boat is, indeed in the middle east, Basrah, but I don't have any knowledge of the geography of those parts.
                                              The photo you have attached of a similar craft is very useful. I'm sure I will have plans for a similar shaped craft and can make a suitable hull with just the top hamper changed to make it a RAF craft.
                                              Cheers,
                                              Martin
                                              #77452
                                                Hi Martin
                                                I see what you mean about pipes however I think that these could be timbers laid in a similar way to those on the cabin roof.
                                                Where does the Basrah reference come from? there is a Al Basrah in Alexandria but it isn't anywhere near a wide river as it only has a narrow irrigation canal.
                                                Edited By Paul T on 09/06/2018 17:42:24
                                                #77453
                                                Martin Field 1
                                                  @martinfield1
                                                  Could be, Paul, once again, to have stuff lashed to.
                                                  I have found a boat by Maynard's yard at Chiswick which is very similar to the 153 boat, being a 1925 35 foot launch. Even if the RAF boat was built by somebody else it is definitely similar enough to use as a guide.
                                                  Let anybody say me nay, eh?
                                                  Cheers,
                                                  Martin
                                                  #77455
                                                    Hi Martin
                                                    Have a look at this Link its a similar style from the same builder.
                                                    Martin Field 1
                                                      @martinfield1
                                                      Ah, that's the same pic. you sent before, except this one is the wider website and description. Lovely stuff. I can work with that. Surprised it's down as such an early boat.
                                                      Thanks for sending that through, Paul.
                                                      Cheers,
                                                      Martin
