Dear All
To explain the principal behind the drawing delivery system.
Normally when someone wants a set of plans they order them from a supplier and after a couple of days the drawings will arrive by post. Usually the drawings are in large sheets such as A0 or A1 size.
With the download process all of the information is sent through the internet via an email attachment, the drawings and instructions are all contained within the attachment in a format called PDF, most modern computers have PDF software pre loaded before being sold, this software is called Adobe Reader and enables the computer to open the PDF documents. Sending the drawings this way means that the end user doesn't need any special computer skills or fancy CAD software.
In fact all that you need is a computer connected to the internet and an A4 printer and the beauty of PDF is that there is no degradation of image or change of scale.
After opening the email all the user has to do is press the print button and their own printer will print the drawings in A4 pieces the user then 'cuts and sticks' these A4 pieces together to produce the drawings. However most pieces such as frames are small enough to be contained within one page so the cutting and sticking is kept to a minimum.
The user can print as many copies as they like which makes the production of cutting templates very easy.
I hope this explains the system but if anyone has any questions please ask
