Time to layout the gear……An important event!
There are a few things to watch out for!……..And no doubt,certain forum members will have something to say about this subject!
I like to use a single board and mount the gear on top, with all the wires out of sight, underneath
The rudder servo is on the left, not far from the rudder…..Obviously
Next comes the receiver, with the On/Off switch below it
Next right is the Electronic Speed Controller……..Note……..Some distance away from the Reciever, to avoid interference…..Above, is another On/Off switch, which is part of the ESC
Next comes the main battery and below that is the Reciever battery and are on the approx. centre of gravity position. The batteries can be moved about, fore and aft for balance adjustment
On the extreme right is the motor drive
In order to achieve a simple looking layout, a few extension cables may be required
That`s about it…….Nothing is fixed at the moment and can be moved about, pending constructive comments
The base board will be screwed to blocks glued to the hull, for easy maintenance
