Prototype build of ELLIE
Viewing 25 posts - 676 through 700 (of 1,441 total)
  • #44310
      Setting up the canopy
      Using custom made height blocks
      The windscreen will be glued to a thin sub base, which will be bolted to the cabin roof
      This will make life easy for painting and varnishing
      The canopy rests on the windscreen and two packing blocks at the back end
      The weight on top ensures temporary rigidity
      When we are happy with the set up. the pivot blocks can be glued in position
        Lovely looking model Bob but it's got Paul's footprints all over it!
          Thank you for those kind words, Colin……….You`ve made Paul`s day
          But you know what they say…….Two heads are better than one!
          The Dynamic Duo
          #44324
            The canopy retracted and the windscreen is bolted down
            What else needs doing?…… I ask myself
            A pair of rubbing strips on the hull side would look nice?……and a couple of scabby tyres
            Paul…..How about a pair of bilge keels for stability?
            A sliding hatch?
            A few bollards
            Glazing of course
            Couple of hooters
            A good rub down with a wet fish…….Plenty of varnish
            The paint job…….OOOOoooo!
            The motor drive caboodle……When it turns up
            Not much else?……….Bob
            #44325
              Rubbing strips would look nice but not sure about putting scabby tyres on your lovely new boat
              Its up to you Bob if you feel the need to fit Bilge keels then please feel free to do so after all it is your model, Mr X has added spray rails to his SeaSpray and I am sure that at sometime in the future someone will add hydrofoils to their version, but from a stability point of view the bilge keels are not necessary.
              A sliding hatch?
              Its up to you Bob if you think that your version will benefit from fitting a sliding hatch then by all means fit one but you already know my views on this subject.
              A few bollards
              I would agree with Fairleads and cleats but not bollards as they might look to chunky.
              Glazing of course
              Of course
              Couple of hooters
              A pair of chrome horns would look nice on the varnished roof
              Lots of rubbing down with 1200grit wet&dry and at least 10 coats of varnish.
              Looking forward to seeing the super smooth coach paint mirror like finish
              Don't forget that there are lots of structural changes to make before the drive system is fitted.
              These are only my opinions and you must feel free to do whatever you are happy doing, the design isn't cast in stone and should be embellished in whatever way the builder feels most comfortable with.
                Thanks Paul
                Just having a look at drilling the hull and keel for the prop tube……..Mmmmmm?……Geeeeez!
                The prop tube will be wider than the keel!…..Going to be fun, going through the keel midships?
                Will need showing on the keel detail, early on in the build……………………For the Noobs!
                The latest prop tube drawing, you sent this week……..Can`t read the small print
                What angle is the design with the 500mm propshaft?………..4 deg?
                Any more clues for the single prop version?
                  To read the small print try using the magnifier tool on Adobe Reader and read it on the screen.
                  The 500mm propshaft angle is 4deg.
                  The keel cutout for a single motor is the same detail as shown on the drawing I sent to you yesterday simply move the 25mm cutout to the existing motor space between Frames 3 & 4
                    Thank you Paul……….I didn`t realise we had the magnifying glass feature
                    Notice how Paul hasn`t commented on how we drill the hole for the propshaft?
                    Well never mind!………I have another cunning plan!………We are going to enjoy this!……..`ish
                    Having drawn out on CAD that 4 deg is equivilent to 10mm drop over a distance of 150mm, I drew the path of the propshaft on the exposed keel section
                    Then using a home made drill, I`ve drilled through along the path
                    Then what?……..Wait and see
                    Only hope my cunning plan works, otherwise I`ll look like a right Gorp!
                      What an exciting adventure, chaps?
                      Here`s a lucky break!…….The prop tube is 6.5mm diameter
                      And the keel is also 6.5mm wide!……….So by clamping a steel plate each side of the keel, we have a super duper guide for my extra long home made drill!………Viz!………
                      Of course there is a highly probable chance of the drill wandering off course….up or down!
                      Never mind that now!……Here goes!…………Brrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
                      Now let`s have a look!
                      To be continued!…………Ha! Ha!……..Bob
                      #44332
                        Splendid!……..It`s worked!
                        Just think!……That`s a 6mm hole through 6.5mm ply!
                        Now need to check the angle of dangle and plan the next move into the unknown and through the rest of the hull!…………Not for the feint hearted!
                        To be continued……….Hopefully…………Bob
                        #44335
                        LARRY WHETTON
                          @larrywhetton68737
                          Hi Bob,
                          another inventive idea , but should putting the shaft in at hull build stage,
                          plus motor mount and rudder , a lot easer when you have more access,…
                          but the build and design is spot on ..cheers LARRY..
                          #44336
                            Thank you Larry
                            I`m getting there!
                            Got some drill wander on the inside……Couldn`t clamp the steel plates securely
                            I`ll sort it shortly
                            PS….Message to the Noobs
                            You won`t have this problem……….The keel will be cut out first to accomodate the propshaft
                            #44342
                              An update on the hole drilling
                              The drill is nearly full depth, but has broken out of the keel
                              Having great difficulty getting the drill to get back on target
                              Might have to resort to some chiselling?
                                Just use a pickaxe Bob – you can fill it in later!
                                  What makes you think I haven't done so, already!….lol
                                  The neat slot is getting more ragged by the minute
                                  There is an area very inaccessible in a bulkhead
                                  P38 heals all wounds!
                                    Can`t do much more on the keel at the moment, until the propshaft arrives
                                    Without further ado……Saw a cruiser this morning with two rubbing strips, so we have two, too!
                                    Now what do we think of the paint scheme?
                                    Lime and Ivory?
                                    We`ll soon see!
                                    Bob…..Brush in hand!
                                    #44357
                                      Lime and Ivory look really good together and should be great on the model.
                                        Thank you, Paul
                                        Here`s the picture you`ve been waiting a long time for?……..
                                        And here`s the second…..
                                        I think we`re onto a winner here, Matey Boy!
                                        Well done Paul……I`ll bet that`s put a smile on your face?
                                        I like it too!………The green is just the job!……….It`s Humbrol No 38 btw
                                        Proud Bob
                                        #44359
                                          Bob, just let me put my sunglasses on first..
                                          Personal opinion….personal opinion is…dont like the veneered stern with this striking colour. Personal opinion is it looks very dark. Looked very nice when everything was wood colour, but with a painted hull (regardelss of colour I am thinking) it looks too dark.
                                          Personal opinion. my taste only. Only making comment as I know you both like to hear an opinion.
                                          Like the ivory, not a common colour, makes a nice change to white or off white.
                                          Like the strakes down the side, adds interest the flatness of the hull side. Some rope fenders would look nice, probably to come, eh?>
                                            I agree with you, Ashley
                                            The sponson veneer is too dark and distracting!
                                            We'll see what the Drawing Office have to say tomorrow, before I put it right
                                            Peter Fitness
                                              @peterfitness34857
                                              Bob, what colour do you plan on using below the waterline?
                                              I agree with Ashley concerning the wood colour, it is rather dark but, again, that's just an opinion. I also like the strakes, they're a nice touch. The colour scheme, while unusual, is very eye catching – I like it.
                                              Peter.
                                              #44363
                                                Its a wonderful job.
                                                The colours including the varnish are perfect and will all make a great background when the finishing details are added, the only bit that doesn't look right are the white plastic angles on the edge of the windscreen these would look better in brass.
                                                  Thank you, Paul
                                                  All the super structure will be painted ivory….including the plastic corners
                                                  Will leave the varnished sponson, for the time being, as I`ve alway`s envisaged the name in gold lettering
                                                  Window frames are on my mind now!……..Ah!……..Just remembered a cunning plan!
                                                  I`ve seen some impressive window framing done using 00 gauge rail section?
                                                  Sounds promising?…….Bob
                                                  #44365
                                                    Minor point but one which for some reason niggles. "Transom" is the rear frame of the hull which forms the flat stern. A sponson is a projection from the side of the hull for protection, stability or mounting weapons etc.
                                                    Builds are both going well. I'm currently in the process of applying lightweight glass cloth and EeZee Cote to the hull of Sea Spray and varnishing the ply deck, which I have stained light teak.
                                                      Thank you Dave
                                                      Just a senior moment……….I meant of course…………"Transom"
                                                      We would love to see you model, please?
                                                      I'm sure the readers would too!
