Propeller Question
Propeller Question
Home Forums Beginners Propeller Question
  • #10583
    Adam Wood
      @adamwood43576
      Hi everyone…. I hope you can help me as this isn’t strictly about model boats, in a way it is though.
       I’m looking to find the best prop design driven using a flow of water (rather than an engine driving water) and I need a number of characteristics if someone can help.
      I require medium torque with high RPM (not the easiest combination) which could be driven from something like the flow of a tap or hosepipe.
      Thanks in advance
      Adam
      John Boyd
        @johnboyd97248
           Try ringing propshop they advertise in MODEL BOATS .
        #10591
        Telstar
          @telstar
          It depends what you want to drive with it.
          It may be more effective to use a paddle bladed device. What you are talking about is a water turbine. These are very different to a normal prop.
          Tried to post a simpl drawing of what I mean, but don’t seem to be able to.
          If you are interested give me a personal e-mail and I will forward a sketch to you
          Cheers [email protected]
          #10617
          Robert Ryan
            @robertryan95520
            Can any one imform in the best way I can water proof the propeller shaft and rudder of a working model boat.
            #10621
              For Robert – the best known way is to ensure that the inner end is above the waterline.  Otherwise, follow the US convention of calling such tubes "stuffing boxes" – they get stuffed with grease.  On a model, light water resistant grease as too much heavy grease introduces drag.
              Another way is to make sure the bearings are a close fit, and that the end play is minimal.  I tend to favour using a small "O" ring as a washer at the prop end.
              #1358
              Adam Wood
                @adamwood43576
