Pot of Gold?
Pot of Gold?
Home Forums Collectors’ corner Pot of Gold?
  • #40032
      My good pal, Duckie hadn`t heard of Shrinlkng Dope before this morning?
      I`ve had this tin of Aeromodelling nectar for about 25 years and could be a collectors item?
      Can we still get this stuff?
          Collector's Item? Nope………
            What a coincidence?
            A chap in the club had acquired a fiery Swordsman and the instructions recommended a dope finish
              Apply it near a naked flame and you would get a fiery Swordsman indeed!
              As I get older I have come to appreciate what shrinking dope actually means…..
                Ha! Ha!?….Nice one, Colin
                I noticed the typo, but left it in, as it seemed appropriate!
                  The instructions would mention sanding sealer, which isn't quite the same as dope in that it has a filler medium. I have recently used EzeKote sealer which would probably be very good with either lightweight glass cloth or even Modelspan tissue, but I would cover it with something to mask the heavy grain of liteply and/or balsa.
                  ojays
                    @ojays
                    Posted by Dave Milbourn on 01/04/2013 12:18:11:
                    As a child I couldn't afford both shrinking dope & sanding sealer. So an older modeller at that time taught me to mix the dope with talcum powder & presto it worked just fine.
                    Apply a coat and when dry rub it down, apply subsequent coats rubbing down between them again, and you end up with a glass like finish ready for painting!
                    Gregg
                    #41468
                      Thank you, Gregg
                      I used to use dope and talc too
                      Once built a Hawker Tempest with 14 coats of paint, it was beautiful……But it crashed first flight!
                      A common event!
                      ojays
                        @ojays
                        'But it crashed first flight!'
                        This was a common thing with my flying too, OK taking off and the flying bit!
                        The landings left a lot to the imagination!
                        Gregg
                        #41484
                          Did you see in the paper only yesterday or so, that a light aircraft had an engine failiure and crashed into a garden…but it was fitted with a large parachute for just this circumstance, and the crash was it simply floating to the gound!! First I have heard of parachutes for light aircraft!!
                          Ashley (but what a good idea)
                          #41487
                            Hello Ashley
                            There was a prog on the telly recently and it was about a company making parachutes for small planes, but it never really caught on
                            And I remember there was one for model aircraft too
                            But my plane was a control liner!….lol
                            There's nowt new in the world………But don't you believe it!
                            Rod smart
                              @rodsmart62545
                              Hi Bob , I would have liked to see that program on fitting parachutes to planes as I have thought about it for airlines. Carn't think how it isn't practical , even to the point that you could put the plane into a stoll to kill the speed and deploy the parachutes. Well it's a thought
                              Rod
                              #41595
                                I thought is was a spiffing idea and for the chap who used it, a life saver. I cant see how it would NOT be practical for small light aircraft. I might see that an airliner `chute would be more tricky, and would probably injure as many people when it was deployed, as gliding to a landing on a field or runway?
                                Bob. I have one aircraft at home, it is a control line job.. an Interceptor from the "Buck Rogers" T.V series. It has a ridiculously small glow engine at the back, but all the control line gear is missing; I > have hankered after getting it going one day. I have a feeling that a small brushless and LiPo pack may be the way to go nowadays. Do they still do control line stuff??
                                  Hello Ashley
                                  Control line flying is still in existence and is nice to watch, mainly for nostalgic reasons
                                  We have a very active club flying at weekends on a quiet area of Barton aerodrome in Manchester
                                  There used to be an international event club in Wigan called three Sisters……Named after three local slag heaps! The Russian models were immaculate
                                  The speed models were enclosed in wire cages and was very exciting to watch…. they only ran for about 15 seconds and they used single bladed props!
                                  I used to be a member of the Ashton club and just for the novelty…..Had a control liner rotating around a central pylon and RC controlled.
                                  It actually appeared in an article in the RCMA magazine
                                  I suppose that you could Google the aircraft parachute info?
