Hi Eddie
As Len says do be careful handeling molten lead.
I bought a cheap stainless steel milk pan, £2.50 at a pound shop to melt the lead in, I dont like trying to hold tin cans etc with pliers etc. Also I use an old spoon, its handel wedged into a a piece of pipe to lift off the scum. To do the work outdoors I fire up a small charcoal barbi. and stick the pan on that, straight on the fire with no grill etc. keeps the fumes out of the house.
With your mold. If you have problems with it coming apart and have to redo it, Do one half and let it go off then coat the surface where the two halfs meet with a fairly strong soapy solution (I use washing up liquid with some water and paint the surface liberally with that) then put in the second half of your plaster. I usually seperate the mold before it is absolutley dry then warm it as you are in a warm dry place.
Post some pics of your boat
Cheers Tom
