Louis Heloise MAR 2431
Home Forums Beginners Louis Heloise MAR 2431
Viewing 25 posts - 76 through 100 (of 178 total)
  • #62029
    Brian Muir
      @brianmuir84327
      Cheers, I am going to make a sand mold and pour the keel. I am going to fit a motor too, I have drilled the hole in the stern, and I need to pick up a shaft and a largish motor, what size was yours?
      Brian Muir
        @brianmuir84327
        The arrangement for the cross piece to be fixed to the rudder shaft looks interesting, not much room under the deck there? It also seems to be closed in by the decking so no access for repairs etc and no way to take off the rudder if I need to enlarge it to get more effective steering.
        #62032
          Hello Brian
          I used a 540 motor with about a 10 to 1 reduction and about a 40dia prop
          The rudder is a bit tricky, I seem to remember, incorporating a square drive at the top
          The pivot shaft was fixed to the rudder and pushed up from below
          Brian Muir
            @brianmuir84327
            Don't know why these pictures keep getting rotated??? Fitting deck beams, cabin coaming and I've used earth cable sleeve to carry the sail sheets to the servo. image.jpeg
            #62049
            Brian Muir
              @brianmuir84327
              #62051
                Hello Brian
                My IPad also has the habit of inverting the photos……Don't know why
                Are you using an arm servo or a drum system?
                Brian Muir
                  @brianmuir84327
                  A drum, did you put steps down into the cabin? B
                  #62062
                    Hello Brian
                    I didn`t fit the steps……..I preferred to have plenty of space for the motor and jelly battery and sail winch mechanism
                    I also fitted a bilge pump……….Which nice to see in operation
                    For the winch, I used a drum servo, driving a gear sprocket, which powered an endless plastic chain around the inside of the hatch opening
                    The sail ropes could then be clipped anywhere along the chain
                    Brian Muir
                      @brianmuir84327
                      image.jpegI have fitted an interior platform for the 600 motor, I plan to have the whole cabin lift off to give access to the electronics. One more level of bulwark planking to do, then the stern. I am going to use parts of a brass rudder system using a circular brass rod filed to a flat edge that will insert into the rudder.
                      #62094
                        Looking good, Brian
                        I notice you've got the prop shaft in position already
                        It may be worthwhile to resist the decking, before a trial hull leak test?
                        Is the kitchen, your workshop?
                        Brian Muir
                          @brianmuir84327
                          Yes I will leave the decking etc for a while, I have to make and fit the lead keel, seal the prop shaft and the rudder post then a water trial! I work in the garage but I bring it in to let the glue dry as it is so cold out there at night.
                          #62292
                          Brian Muir
                            @brianmuir84327
                            image.jpegI have now sealed in the prop shaft and rudder post tube, fitted a larger rudder, but it feels a bit heavy (I suppose in the water it will be lighter) but I might sand it a bit slimmer. Ready for a float test when the aroldite dries!
                            #62294
                              Hello Brian
                              Coming along really nice now
                              Don't like the idea of getting the untreated wood wet……You might get some distortion?
                              Don't risk it
                              Brian Muir
                                @brianmuir84327
                                Yes, that makes sense Bob, I had better prime and paint the hull first, it should cover any weak spots too. Cheers, B
                                #62299
                                  Hello Brian
                                  Looking at the last photo…….The rudder looks a bit oversize?
                                  Brian Muir
                                    @brianmuir84327
                                    I did make it larger than the one in the plans, I often find the rudder that may look nicely proportional isn't very effective. I can reduce it later after I have tried it out. It will also have a large section cut out for the propellor which will also reduce its effect.
                                    B
                                    #62427
                                    Brian Muir
                                      @brianmuir84327
                                      image.jpegTwo coats of primer and two coats of enamel satin finish, to let the planking show in the highlights.
                                      #62448
                                        Hello Brian
                                        Progress indeed!……Time for a bath test?
                                        Just a suggestion……I have always avoided the jet black hull colour look……It looks very aggressive on a model
                                        Try a dark shade of grey and compare the effect?
                                        Brian Muir
                                          @brianmuir84327
                                          image.jpegYou must have reading my mind Bob, all dry inside after 20 min in the improvised dam. Not sure about the hull colour, interesting comment, I'll have a think before I do any fine detail painting.
                                          #62460
                                          Brian Muir
                                            @brianmuir84327
                                            By the way, the anvil and tin of lead used as ballast weighed 12lbs, and she still seemed quite high in the water. When I cast the lead keel it will of course provide more stability and need not be the same weight.
                                            #62462
                                              Hello Brian
                                              The designer admits in his write up, that he never used the correct ballast for some reason
                                              Don't think he specifies the correct ballast weight
                                              I only used 9 lb and it did sail high in the water, but the deep keel kept the boat upright
                                              Being a very bulbous hull, you can go to town…….If you can lift it!
                                              Brian Muir
                                                @brianmuir84327
                                                A bit worried that the cutaway rudder has weakened it, may have to make another with some reinforcement, or use a smaller prop.
                                                Edited By Brian Muir on 05/01/2016 13:31:46
                                                #62479
                                                Brian Muir
                                                  @brianmuir84327
                                                  image.jpegQuite a size with mast and bowsprit in place, They have to be removed for transportation or buy a bigger vehicle!
                                                  #62482
                                                  Brian Muir
                                                    @brianmuir84327
                                                    I have also noticed there is not enough room under the deck level for the steering bridle on the rudder post as it turns. I will have to fit a raised section to sit over it. Not sure why I don't have room, I have actually cut away part of the keel so that the tube for the rudder post doesn't stick up very far.
                                                    #62493
                                                      Hello Brian
                                                      I remember the shortage of space at the tiller handle area
                                                      The attached photo may be of help?
                                                      Don`t forget the handrail capping
                                                      Contemplation
