Louis Heloise MAR 2431
Home Forums Beginners Louis Heloise MAR 2431
Viewing 25 posts - 1 through 25 (of 178 total)
  • #51366
    Brian Muir
      @brianmuir84327
      Hi there I am starting this model, I have looked closely at Bob Abell's album, unfortunately some of his instructions have been cut from the images and the images are fairly large scale views.
      I have made an angled ramp for the keel, and I'm off shopping for a suitable piece of wood for the keel, Bob used mahogany I think. He also used Obechi (?) wood for the planks, I wonder if this can this be bought ready cut to 10 x 3 x 100 lengths? This will be my first attempt at planking so any tips welcome.
      Brian Muir
        @brianmuir84327
        Scratch building this model
        #51368
        Brian Muir
          @brianmuir84327
          This is You Tube footage from France
          Edited By Brian Muir on 17/08/2014 20:52:44
          #51369
            Hello Brian
            Pleased that you have started a thread for your Louis Hloise build
            I originally cut up an old mahagony door for the keel and structure
            I did use Obechi for the planking but wouldn't recommend it, as it is too soft and fluffy for sanding
            I would recommend pine for the planks….And remember not to sand the planks too much
            You need to see the planks
            The camber was about 10mm at it's highest point
            All the best
            Brian Muir
              @brianmuir84327
              Someone else has suggested lime 10 x 3 mm for the planking, but I have heard this is too soft for this…. Will pine 10 x 3 bend and twist?
              #51813
              Brian Muir
                @brianmuir84327
                Hi Bob, looking at your picture below, there appears to be an extension to the stern section of the keel above the transom, but I can't see this on the plans, was it a temporary fix to help you line up the frames etc?
                #51814
                Brian Muir
                  @brianmuir84327
                  image.jpgHere is the relevant section of the plans
                  #51815
                    Hello Brian
                    That piece jutting out is part of the hull!….It is quite delicate
                    All the formers need a temporary crossbar. Mark the centres on each one
                    Lay a flexible straightedge along the top of the cross bars from the prow to the jutting out piece and use a small spring clamp, to hold the formers in place
                    Don't forgt to chisel out the planking slots in the prow upright…..This is important when the planking is being laid
                    Use 10mm x 3mm planks
                    Be very precise with the first pairof planks at the top of each former…..Especially at the rear end
                    You can't be too careful at this stage
                    Check for symmetry and accuracy as you go
                    Fit the first pair without glue, to give you time to do a good job…Then go round the joints with runny super glue
                    All the best….Take your time and be precise…..You have a big job ahead of you!
                    Do not sand the plank joints too much, as the planks need to be seen
                    Brian Muir
                      @brianmuir84327
                      image.jpgKeel completed, including additional piece of the stern! Made from Sapele wood, incredibly fine red dust when sawn or sanded, looked like a scene from Psycho when I stood under the shower.
                      #51835
                        I recommend you make provision for a 1 metre type ballast keel in the keel at this stage
                        A slot about 16mm wide x 150 mm long should be ok
                        Brian Muir
                          @brianmuir84327
                          I have left a section of the lower keel for this, at the moment it is a wood section screwed in place. I have used a solid piece of lead hammered into shape in the past.
                          B
                          #51844
                          Amy jane September
                            @amyjaneseptember49770
                            Hi there Brian
                            I shall look forward to following this build.
                            All the best
                            Amy jane
                            #51918
                              My hull just for reference
                              It`s unusual to plank a hull, the right way up!
                              #52158
                              Brian Muir
                                @brianmuir84327
                                image.jpgHi Bob, I have cut the frames and placed them in position but when I fixed a trial plank along each side they didn't seem to line up at the stern with the top of the transom. Nothing is glued at the moment, how flexible can you be about the position of the frames?
                                #52159
                                  Hello Brian
                                  Need to see where things are not lining up?
                                  I see you have omitted the temporary cross bars……..It`s risky
                                  The planks you are using are too thin!…….Try 6 x 3 section
                                  Locate the planks fore and aft and study where the planks touch the frames
                                  Don`t expect the planks to touch all the frames and don`t force the planks into the hollows ( I see you have tried that and looks very poor)
                                  Let the natural flex of the planks be the final shape of the hull………This is essential
                                  Looking at the first photo, the keel assembly looks twisted….Or is it camera distortion?
                                  The elastic bands you are using don`t look man enough?
                                  You are at a very tricky stage…….Be careful
                                    Hello Brian
                                    Looking at your photo`s again
                                    The formers need to be a very loose fit on the keel, to allow the formers to self centre with the planks
                                    Brian Muir
                                      @brianmuir84327
                                      Hi Bob, yes I cut a 1mm plank which just bent too much, I have now used 3mm as per the plans and it is lining up much better, the frames are very snug on the keel, (which is straight thank goodness) so I will file them a bit to let them shift into shape with the guide planks. I'll then sand the edges to fit the curve of the guide plank, and mark the position and glue each frame in place. The elastic bands are pretty good but I'll be making up some hooks to allow them to be tighter as needed. I am going to fix some temp cross bars that extend above the deck so I can fit the planks on the upturned hull.
                                      #52172
                                      Brian Muir
                                        @brianmuir84327
                                        p1020963.jpgI am still having a problem with the transom, it seems too large, the guide plank doesn't line up with the top of the transom but about halfway down…..
                                        I could add some timber to the stern keel section, and shift the transom downwards, or as in this picture, I have reduced the size of the transom
                                        #52173
                                          Hello Brian
                                          I do remember this stage
                                          Don't forget, more planking is added above the former height after planking the hull, so the transom is not too low
                                          LH page 9
                                          #53095
                                          Colin Leadbetter
                                            @colinleadbetter85912
                                            Sorry to barge in here but the plans don't seem to show any details of the deck beams. They seem to have a slight concave curve – can anybody advise?
                                            Thanks, Colin
                                            #53099
                                            Colin Leadbetter
                                              Sorry, that should have been "convex"
                                                From the bows to the stern, the deck is concave
                                                From port to starboard, the deck is convex with about 8mm camber
                                                All the best…..Bob
                                                #54329
                                                  How about an update on the build, Colin?
                                                    A reader, Steve Smith has asked a question regarding the rudder mounting on Louis Heloise model
                                                    I`ll use this thread to reply…..
                                                    Steve……..I`m not surprised you`ve asked this question, as the method is quite tricky
                                                    The bottom pivot is a straight forward pin in the rudder, pivoting in a drilled hole in a brass bearing plate, screwed to the keel
                                                    The top pivot is a short shaft, pivoting in a top bearing plate, with the shaft mounted in the rudder
                                                    The top of the rudder has a brass plate fastened to it. The plate has a square hole and the pivot shaft has a square section, which engages with the square hole
                                                    The servo crank is below deck
                                                    Hope you can understand my explanation………Just ask if you need more info
                                                    LH page 19
                                                    #58661
                                                    steven smith 6
                                                      @stevensmith6
                                                      That sounds good Bob, I was toying with the idea to use a normal shop bought brass rudder, and cutting it into the timber rudder that I've made, I'll use the pin and plate at the bottom though,
