LCT Ramp Mechanism
LCT Ramp Mechanism
Home Forums Build Blogs LCT Ramp Mechanism
  • #97463
    Silverfern Downunder
      @silverferndownunder
      Hello to All,
      I am seeking ideas for the ramp mechanism on my landing barge which I'm currently slowly building from no plans.
      For those of you that have built an LCT with a front operating ramp door I would be interested in how it operates up and down. A picture tells a lot if you have.any.
      Thank you
      Robert
      Downunder.
        Seeking Ideas
        #97464
        Charles Oates
          @charlesoates31738
          I made the rear ramp open and close on a ferry, it's much the same idea as your model. Because I'm a believer in keeping it simple and robust, I abandoned the idea of scale fidelity, and just made it work. I used control snakes, like the aircraft boys use to small control horns on the door. The other ends want to extended servo arms and the two servos connected via an action servo morph and a y lead to the receiver. Dead simple and cheap, the servo morph is a brilliant piece of kit for setting up things like this. I made one mistake at first, I didn't allow for fine adjustment of the servos in their mounts for setting up. I suppose it's obvious, but make sure the two servos are the same type.
          Charles
          #97465
            Excellent info Charles, thank you kindly
              As Charles I have used 2 servos and aircraft snake and a servo morph. This was for the Stern Gate on my Graupner Bernhard Gruben. The servos were mounted on a rubber two sided tape just to give it a bit of give when it closing. It did take a bit of patience and time to set up.
