Increasing model top speed
Home Forums R/C & Accessories Increasing model top speed
Viewing 3 posts - 26 through 28 (of 28 total)
  • #82228
    Paul75
      @paul75
      Thanks for your replies.
      Just to clarify, I have a 12V 5Ah NiMH battery installed in the model, as per my original post.
      The 2.5:1 geared MFA motors originally installed in the model gave 6300 RPM on 12V, according to a supplier's website. Since I would like the model to be about 50% faster than it was with these motors, would the 12000 RPM of the 775s not give a useful extra margin of performance over the old setup in order to achieve the desired speed? As suggested, I could fit a lower voltage battery (or use less throttle) if the speed is too great at maximum throttle on 12V.
      Many thanks,
      Paul.
        Yes.
        Paul75
          @paul75
          Hello Everyone.
          I finally managed to sail my Drumbeat of Devon which is under renovation, having installed twin 775 12V motors and with a new 12V 5Ah battery.
          I was very happy with the extra performance – a bit over scale speed at full throttle.
          I managed to get 15 minutes out of the battery by only using full throttle sparingly. I'm planning to install a second battery through an Action Electronics P103 Parallel Power Board for extra run time.
          Thanks again for all your advice.
          All the best,
          Paul.
