I am fitting a sound board
Home Forums R/C & Accessories I am fitting a sound board
  • #13870
    Geoff Bird
      @geoffbird11926
      Hello Everyone
      My R/C is 3 channel. At the moment I am only using 2 and want to use the 3rd as a switch to
      turn a sound board on and off. Do I have to somehow make the servo arm operate a mechanical switch or is a switch available that works directly from the receiver. If there is could you point me in the right direction.
      Many Thanks
      Geoff
      Jake Knight
        @jakeknight71345
        hi geoff
        theres 2 ways you can go about doing this
        first is to do the way you suggested (uses the servo arm to switch a switch) the best switch to uses is a micro switch which can be brought from many hobbie shops
        the second way is to get a switch whcih fits directly onto the servo (also as you suggested) but these can cost more money but could be more reliable
        hope this helps
        jake
        #13881
        Len Ochiltree
          @lenochiltree67043
          Hi Geoff,
          Most comercial sound systems plug in to the Rx,If you are making one from Maplins etc then do as Jake says.
          Len
          #4959
          Geoff Bird
            @geoffbird11926
