help with fitting horse shoes
Home Forums Sailing Models help with fitting horse shoes
  • #64460
    christopher jones 5
      @christopherjones5
      Hi I own a smaragd yacht and wondered how do people attach horse shows for added detail
      christopher jones 5
        @christopherjones5
        #64461
        David Marks 2
          @davidmarks2
          Christopher – Could you show or illustrate exactly what you mean by horse shoes?
          #64468
          Telstar
            @telstar
            Hi On sailing ships there was a deck fitting called a "horse".
            Shown here **LINK** .I remembered the term being used sailing Marbleheads many years ago
            Old Guy Tom
            #64470
              Old Guy Tom
              Bang on the money, these deck fixtures are almost as old as sailing and the term 'Horse' comes from English late middle ages when they were constructed from heavy timber, it was called a horse simply because of its likeness to a carpenters saw horse, which itself was called saw horse because it four legs and a strong back.
              I found this out many years ago, I had taken my Hillyard into Dickies on the Menai Straights, as it was a timber boat it attracted the attention of many people including an old boatbuilder who, over the next few days and during many convivial pints taught me more about timber boat construction then I could have ever have learnt in a classroom.
              Happy days
              David Marks 2
                @davidmarks2
                So assuming the information posted by Telstar is correct and the `horse' has already been made. To fit the horse is just a drilling operation. Firstly drill a piece of scrap material to obtain the optimum size of the drill for the material i.e so that it is a push fit into the hole. Drill two holes at the correct distance apart (or pitch) in scrap material. Some trial and error may be required to get this correct. Once you have two holes of the correct diameter and pitch, transfer the piece if scrap to the model and locate in the correct position using double sided tape. Then just spot through the two holes to the depth required and then remove the piece of scrap, or to give it its correct terminology ….Drill Jig.
                #64504
                christopher jones 5
                  @christopherjones5
                  I’m talking about the life saving equipment I’d post a picture but I can’t see a button to attach photos
                  #64506
                    Posted by christopher jones 5 on 13/04/2016 13:23:32:
                    I'm talking about the life saving equipment I'd post a picture but I can't see a button to attach photos
                    Scroll down to Forum FAQ's
                    Edited By Dave Milbourn on 13/04/2016 13:36:43
                    #64507
                    christopher jones 5
                      @christopherjones5
                      I’m on a phone device not a 0c
                      #64508
                      christopher jones 5
                        @christopherjones5
                        Pc
                        #64509
                          Lifebelts, whether round or horseshoe shaped are mounted on a quick release bracket attached to the boat's railing or stanchions.
                          christopher jones 5
                            @christopherjones5
                            #64519
                            christopher jones 5
                              @christopherjones5
                              Yes ino how it is mounted but does anyone know where I can buy a model sized bracket for me to attach onto the railings of my yacht
                              #64521
                                Simple to make, just bend a bit of brass or aluminium sheet. I very much doubt if you will find any commercial items.
                                  Hello Christopher
                                  I don't know where you live but if you are close to a B&Q or other DIY outlet they will have some pre-bent furniture fittings that might do the job or they do sell lengths of brass, copper and aluminium tube / bar so, as Colin says' you could make your own. If you do live miles from anywhere you could go on line and look at Screwfix as they sell the very same things as B&Q.
                                  Hope this helps
                                  christopher jones 5
                                    @christopherjones5
                                    Ok thanks for the help
