Got around to almost finishing this conversion, the next stage was to change the radio gear to 2.4ghz. I was really undecided whether to keep the model on 40mhz but it's no good living in the past (with r/c etc) and best to move forward.
That is where the fun begins. Bob, when you were building your Glasgow you asked about my ballast, which was described as concrete. It was, and it had been poured in AFTER the radio gear had been installed. The aerial wire for the 40mhz was buried in the mix and had to be cut, which was easy enough, but I decided to change the rudder servo which was also set in the concrete and what a job to get out. I thought about changing the plug on the Sanwa servo, but decided against this. Welcome to the Model Boats forum department of Civil Engineering, Construction or Building Trade, whatever it is called. I never thought a DIY hammer drill and masonry drill bit would be required on a model boat! The removal and enlarging the cut-out in the concrete ballast to fit the new servo wasn't easy, but I finally got there and sealed the concrete afterwards.
The wooden servo tray was re-fitted after and the new Hi-tec rudder servo installed. The tray is just glued on, but where possible I like a mechanical fixing and decided to make a screw in aluminium angle bracket. The bracket's holes match up with the holes of the re-sited switch bracket on the other side of the bulkhead (which will be shown with the next stage).
Bob, again with second hand models you had problems with the Starlet, I had earlier problems with the Glynn Guest Phantom and with problems with this, it makes me wonder about some of the build qualities of some of the second hand models on the market.
The above photographs show the ballast modifications and the rudder servo loosely in place.
The above two photographs show the rudder servo fitted and the angle bracket.
