Glowing with Power!
Glowing with Power!
Home Forums Collectors’ corner Glowing with Power!
  • #11131
    Vinnie Branigan
      @vinniebranigan92297
      The model glowplug engine in the boats of the 60’s and 70’s by David J. Wiggins with thanks to Malcolm Stride.
      Vinnie
      Ray Beresford
        @rayberesford98549
        Hi
        I have I believe a Merco 61 marine engine with external water cooling. I need help! the boat and and engine have been stored for many years and when I decided to bring her out of retirement the engine is seized, not with corrosion but seems to stuck with the old lubricating oil solidifying. I have tried various solvents and easing oils with any success. Any ideas would be appreciated.
        Ray B
        #17609
        John Christopher
          @johnchristopher11781
          Hello,
          Its the castor oil which causes this, it sets like glue….The best way is to strip down as much of the engine as possible (cylinder head and crankcase cover) then soak it in fuel for a while, this usualy breaks down the castor.
          Regards,
          #7392
          Vinnie Branigan
            FEATURE
