fiberglass hull
fiberglass hull
Home Forums Beginners fiberglass hull
  • #104295
    Stephen Mackereth
      @stephenmackereth38870
      Hi all!
      Im not exactly a beginner, but I am, a lock down first timer, self taught. So much to learn (dont get me started on rigging…yet!)
      Anyway finally really getting on to my Deans Marines Victoria and Albert. If anyone out there has built one please let me know.
      Anyhow first dumb question: do I need to treat the fiberglass hull in any way before painting? i.e. is it waterproof?
      If you can answer this and possibly more silly questions as I go on Id love to hear from you.
      Thanks S
      Stephen Mackereth
        advice please
        #104314
          Hi Stephen and welcome to the forum.
          The fibreglass should be waterproof but, if there are any air holes in the resin you might get an ingress of water. A test in the bath should help prove it is sound.
          The first job is to give the hull a good washing down with warm soapy water and detergent to remove any release agent that may have been used. Then you want to roughen up the surface with a fine wet and dry paper before you fill in any imperfections with something like a car body filler such as Isopon P.38. When the hull us filled and smooth a coat of primer should be next. This will help you see any final imperfections that might want addressing. When all remedial work has been done a final coat of primer should give you the best surface for the top coats.
          No such thing as a silly question, only silly answers, feel free to ask away!
          #104322
          Stephen Mackereth
            Many Thanks Richard. Thanks for prompt, and very helpful reply. S
