Hi both,
I followed your discussion last year but as I didn't have any sets mentioned did not expect to use your passed on knowledge. However, at the IMBS last November I purchased two cheap 2.4 GHz sets (£25 each) with the precise intention of using them for childrens have a go boating, but in model yachts only. They were a pair of Radiolink T4EU 4 channel complete with receivers.
Today I thought I'd take a set out and try it in one of my small tugs, just to set it up and get a feel for it, and to establish how to restrict stick travel etc as it would be used by small hands. Experience with children's transmitter usage means "if it moves waggle it like mad" or "push/pull it through the stops as hard as possible cos it'll go faster" etc etc.
So, in mode two, LH stick is throttle (up/down) and RH stick rudder (left/right). All worked well on installation and no problems with receiver binding. If anything, the servos have just a bit more travel but no other problems at all.
NOW as the ON/OFF Is another switch that little hands can find, I wondered what would happen if the transmitter is turned off first. LUCKILY I tried this out of the water, with the top off the tug anticipating the worst – and YES – FULL throttle ahead.
Remembering your discussion above, I selected mode 1, and changed the servo plugs over and reversed operation on them and got the Tug back to the same sticks doing the same control. This time switching off whilst bound to the receiver resulted in the throttle remaining at whatever setting it was in when the signal failed – it did not goto center (off), or one end, just held position. Switching back on regained control.
Nowhere does the word failsafe get a mention in the user manual (on-line only) and nor does the unit mentioned the default in mode 2 as being to full throttle.
As it's intended use is for a yacht I've no problem, especially in mode 1 as I set now. It just goes to proove, you get what you pay for! Oh, and I've adjusted failsafes on my other gear too, at least with them they have a section in the manual explaing how to set one, and how you can create your own default too.
Kimosubby
