Electric boat experts here please!
Home Forums R/C & Accessories Electric boat experts here please!
  • #14441
    Brian Fry
      @brianfry61832
       I thought I had got a real bargain when  I recently bought an ESC for my boat .
       I carefully checked that it was for brushed motors and that the current limit was ok and that it had a battery elimination circuit .
      When it arrived I found it didnt have a reverse!  (It was clearly marked PLANE)
      Possibly fortunately, I was going to use  my very old 4 channel radio set so I thought, why not use a spare channel to reverse the polarity of the motor?
      I figured a D.P.D.T. switch would do this , but before I go any further and blow anything up, could anyone advise if this will work and/or any problems likely?
       Thank you
        Brian. Cant see why this wouldnt work, BUT I am not sure how the ESC will react if there is a modocum of power going through it when you suddenly reverse the motor (duck attack).. May get spikes or peaks above the current capabilities of the unit ( due to heavy draw on initial motor start-up).  Ashley
        ps fusing it might stop ESC damage but leave you stranded in the ocean…
        #14446
        Manxman
          @manxman
          Hi Brian,
          In theory it seems ok, worrying though about being stranded in the lake.  Personal I would put the ESC to one side (in case you build a racer type which only has forward) swallow my pride (I’ve done a lot of that!) get the old wallet out and buy another.
          You didn’t mention where you got your bargain from,  wasn’t Ebay was it ? as most of these are from China/Hong Kong  with a massive rating and are forward only, fine for the old racer.
          Cheers – Ken
          #14456
          Brian Fry
            @brianfry61832
            Thanks for your advice members.
            Ashley,I take on board (no pun intended) your points, although I was planning to close the power  to zero on the  throttle stick before moving the reversing (elevator) stick to the revers position.
            Manxman you got me bang to rights: it was Ebay and for less than £5 delivered it seemed worth the gamble!
            I guess I was concentrating on making sure it was a brushed motor item as there seems to be a big difference in prices between brushed and brushless ESC’s I wonder why that is?
            #14469
            Manxman
              @manxman
              Difference in price ? – simple, new technology (well newish) and a limited market.
              New stuff, doesn’t matter what it is, is always more expensive when it first comes out, but soon drops
              I bought a Sony digital camera 3 years back, cost £230, you can now pick up a much better version for just £70
              With regards the ESC,  I use Mtronics 25amp Vipers (£36) – bear in mind you can move your ESC from one boat to another, after all, you can only sail one at a time –  Its also wise to buy a little bigger than you need as you don’t know yet what your next model will be !
               Ken
              #4976
              Brian Fry
                @brianfry61832
