Differential Steering
Home Forums R/C & Accessories Differential Steering
  • #10330
    stewart somerton
      @stewartsomerton50348
      I recently bought (off e-bay)a cheap r/c speed boat. So that I can race wife,who has same,I am trying to up grade radio system(a bit)the boat has a so called differential stearing system,push stick to the left and power is cut to left motor/prop.It works quite well and I’d like to keep it. I quess I’m looking for some kind of relay that will work from a basic 2 channel receiver,taking power from speed controller to each motor via relay operated by stearing out put.
      As you’ve probablly quessed by now I know next to nothing about r/c systems so this may not be possible whith “over the counter” components.The other alternative is to use two speed controlers(one for each motor) but is it possible to run second controller from stearing out-put? Any suggestions,however obvious they seem to you,greatfully receieved
      yours humbley stewart.
      Graham Haden
        @grahamhaden82325
        Each motor requires an ESC, The throttle & steering from the RX go in to the unit, the outputs are to your steering servo and 2 or 3 speed controllers “ESC”
        Check this out http://www.action-electronics.co.uk/
        #10446
          You can hook two ESCs and a ruuder to a two cannel set using a mixer. This will give differential steering, only better, because it will be proportional. The rudder is optional in this case.
          #10448
          stewart somerton
            hi,thanks for the suggestions.But i think you chaps have underestemated my ignorance.I’m still not clear that a ESC (electonic speed controller?) will operate off channel 2
            the same as it will off channel 1.I guess i’ll find out as
            soon as it arrives from honk kong.In the mean time i have
            fabricated a simple (some might say crude) servo operated
            switch to cut power from one or other motor I’ve yet to see
            how well it works under load.However I’m keen to know where
            I might source aforsiad mixer
            many thanks Stewart
            #10449
            Graham Haden
              @grahamhaden82325
              Mixers are available from
              Barry Blyth [Barry@kleefeld.freeserve.co.uk]
              #10452
                As far as the RX is concerned, the ESC is just another servo. In the elder days, a servowould work a controller via a linkage, the ESC avoids having the linkage and quite often issmaller than the servo in the first place. Nothing wrong with the switch arrangement apart from it being a lot less progressive than the full ESCs + mixer arrangement. A lot cheaper as well.
                Mixers available from Action, Mtronics and several other manufacturers. Have a google for “RC mixers”.
                #4912
                stewart somerton
                  dumb question
