Bending Brass Tubing
Home Forums Building Kits Bending Brass Tubing
  • #57642
      Does anyone have a good way of bending brass tubing? I need to make a bar mast for a Graupner Bernhard Gruben model , but the 4mm tubing needs to be bent through almost 90 degrees. All my attempts so far have produced a kink in the bend. I have tried using a wooden dowel as a former and the bending springs . I read on the Net that filling the tube with dry sand works but when I had a quick try yesterday I couldn't bend the tube! I may have another try with the sand later. I would like to keep the tubing open for lighting wiring. I see that there are tools available from Expo etc but at a tenner plus this seems a lot for 4 bends.
      Any help would be appreciated.
        #57643
          Hello Tim
          Bending tube is a tricky job
          You really need to make a bending former on a lathe
          Turn a grove (with a circular bottom) in a piece of round steel, to the size, the bend needs to be
          Anneal the brass with a blow lamp, by getting it cherry red and plunging into cold water
          Place the tube in the groove and bend it round with your fingers…….The brass will be very bendable now that it`s been freshly annealled
          You could also use solid brass rod, but you would still need the bending former
            Thanks Bob
            Unfortunately no lathe or blowtorch. I could probably get the torch passed the holder of the household finances but not the lathe. There is a small pipe bender in the Expo Tools catalogue, sort of like a mini plumbers tool. Do you know if they work? Would it help if I bought some 4mm copper or aluminium tube.
            #57648
              Hello Tim
              You could make a bending tool, using a of with the required diameter and with two washers spaced apart to suit the tube and two nuts!
              Us that cheap enough?
                Sorry Tim….My last message has got a bit garbled
                You could make a bending tool, using a bolt of the right diameter and with two washers, spaced apart to suit the tube and two nuts
                Mark Jarvis 2
                  @markjarvis2
                  Hi Tim
                  Was watching how its made on tv, They were bending brass and copper tube by crimping one end after annealing, filling full of water then freazing it, The former looked to be a piece of broom handel in a vice.
                  They made it look easy LOL.
                  Mark
                  #57662
                  Charles Oates
                    @charlesoates31738
                    Hi Tim, I had a similar problem recently, and I don’t have any special tools or skills.
                    For the tube that needed a sharp bend, I used copper, when annealed, ( heated and cooled) it bends very well for several minutes. I started the bend, then filed a notch on the inside. That allowed me to re anneal it and finish the bend. Lastly I cleaned the join and put a little solder on the join to make it solid.
                    If you try this, you will probably take a few tries with the file to get the notch right, and a little solder means just that, or you will have an ugly join. Practice with some spare tube first.
                    #57663
                    curly
                      @curly
                      Hi Tim
                      I bought a pipe bender from screwfix, to make cooling coils for brushed motors, it works fine. It has three settings 3, 6, 9, mm. the tool works like a pair of pliers .Hope this is some help. Beat of luckyesyesyes
                      Regards Curly
                      #57679
                      CookieOld
                        @cookieold
                        Hi Tim , The sand method works so long as you use annealed tube , if you have no blow lamp then buy ( SOFT BRASS TUBE ) from the model shop and use a nut and bolt former as Bob says .
                          Thanks for all the help.
                          On to the next problem.
                          #57776
                          Mark Jarvis 2
                            @markjarvis2
                            HI Curly
                            The pipe bender you mentioned from Screwfix, what was the item code as i cant find it in there catalogue
                            Mark
                            #57777
                              The aforesaid Screwfix Pipe Bender is made by Rothenberger
                              Model No 79571
                              For pipe sizes 6mm to 10mm dia
                              Price £21,99
                                There is a small pipe bender in the Expo Tools catalogue for 12.95 plus p&p. It says it's for up to 6 mm.
